Re: New school Coils And Distributors vs Old School
[Re: Sb Valiant]
#1335801
11/15/12 06:03 PM
11/15/12 06:03 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
You didn't say what type of distributor..is it a points style or electronic? I'm assuming you have Accel stuff which is very good.I'd be suspect of the coil,expecially being that old.
FWIW.... I still use a Chrysler/Mopar race ignition system that has been in the car since 1981,it works fine and I see no reason to change it.
[Re: dogdays]
#1335809
11/15/12 11:53 PM
11/15/12 11:53 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
If the ign you have now is doing its job you may not see any performance gain at all. Dont matter if you have 35k or 65k firing your plug as long as the 35k is enough to fire the plug in your cylinder it will do the job fine. Once the mixture ignites right 40,000 more volts wont make it work any better or go any faster. If you have a problem then yes you might run better but unless you have a missfire from lack of voltage for one reason or another and its a basic street/strip car I dont think you will have a performance gain. I guess what I am saying is that if your ign can give 35k and it fires all the plugs in your eng fine upgrading to a system with a reserve voltage to 60k wont help as the ign will only use the voltage it needs to fire the plugs. My son switched from the MP orange ECU to the MSD 6A box and from the Acell Super coil to the MSD coil in his mid 11 Dart and ran no different at all. His old setup with the Super coil and MP ECU did the job just fine on his car and the MSD had zero performance difference. Nothing wrong with upgrading to a better ign that might fire your plugs when they get worn or half fouled better then your old ign but if your old ign fires the plugs fine normaly you wont see a performance gain. The good thing about the MSD modern ign is it can fire a worn plug your old ign may not or if you have plugs get gapped to wide by mistake the new MSD may still fire it when the old ign my not. I actually use my sons old Acell coil and MP orange ECU on my 63 which it works fine running 10's shifting at 6200 rpm. I am just saying dont hope for some big performance gain if your old ign is working good. Ron
[Re: Sb Valiant]
#1335811
11/16/12 12:10 AM
11/16/12 12:10 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
The better spark the faster fuel will burn! Looking to do that so we can add even more fuel. Advancing the timing helps burning more fuel as well too!
The fuel will only burn as fast as it can burn no matter how much spark you start the fire with If you add more fuel and the car goes faster it wasn't tuned to max power to start with, you should be able to fatten the mixture(jetting) up enough to slow the car down in the 1/4 mile, if you can't you don't have enough fuel delivery To much gasoline will flood the cylinders and make the mixture to rich to make optomin(SP?) power, nitro, deisel and some other types of fuel are not like gasoline is.As far as advancing the timing to make more power only works if you didn't have the proper timing to start with There is a best tune up for all application, it may not be the same in two hours BTW, the MSD 6AL is a good box for most N/A street and strip applications I like and use the MSD Seven sereis race boxes with the appropriate coils and spark plug wires
