BB full time rocker oiling...restrictor size... #1335524
11/14/12 11:47 PM
11/14/12 11:47 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Going to drill/tap the oil galleys to convert to full time rocker oiling.
I have a couple questions.
1.I am using Erson needle bearing rockers. What size restrictor do I need? I am very concerned with burning pushrod cups...my only reason for converting to full time oiling. Ive fought burning up cups on 2 motors. This motor will have a solid roller, so I dang sure want oil to the cups...
2. Is putting a restrictor in the deck of the head or deck of block the only way? Anyway to put a restrictor in the feed hole under the rocker pedestal....So I can change restrictor size without pulling heads?
3. Should I block the feed holes to the rocker tips to force more oil through the cup area? I blocked the tip feed holes on one set of rockers, but that was with flat tappet springs. Should I be concerned with roller springs needing more oil and not plug the tip feeds?
Thanks for any help!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: BB full time rocker oiling...restrictor size... [Re: Von] #1335525
11/15/12 12:02 AM
11/15/12 12:02 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Restrictor in the deck is pretty much the only way to do a "removable"
restrictor. If you tried to drill & tap up at the pedestal you'd be risking the integrity of the rocker shaft stud.
I wouldn't block those holes. Harland Sharp doesn't put holes in theirs for spring oiling and I'm concerned with it! And if you watch the oil flow by priming the motor you're going to be shocked at how the oil really only dribbles out of those holes. It will be the rocker motion flinging the oil that provides the lube to the pushrod cups.
Re: BB full time rocker oiling...restrictor size... [Re: Von] #1335526
11/15/12 12:09 AM
11/15/12 12:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What size is the passage ?
Re: BB full time rocker oiling...restrictor size... [Re: Von] #1335527
11/15/12 12:23 AM
11/15/12 12:23 AM
Von, it is a lot easier to have the number four cam journal grooved than it s to drill and tap the block oil galleys I did two blocks by drilling and plugging and then I bought a Crane solid roller cam that had the number four journal grooved Groove the cam instead and then thank about using a .040 to .080 restictor in the stock oil galley to the rockers I use a .039 restrictors on my SR heads with T&D single shaft rockers full time oiling from the lines(one for each line) in the back and a .080 on another motor that oils the rockers through the stock oil galley in the block, both work well. The World iron blocks that oil the rockers full time, both the Wedge and Hemi blocks, use a .040 restirtor in the oil galleys
Re: BB full time rocker oiling...restrictor size... [Re: Von] #1335528
11/15/12 12:50 AM
11/15/12 12:50 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i can't remember if i've managed to restrict the oil feed in the pedestal or not, i won't say it's out of the question. depending on the diameter you can often just tap to a standard size. i normally install the restrictions on the deck surface of the head using a setscrew drilled to .060" and groove the fourth cam journal. on B1 heads i put the restriction under the rocker stand. i would not plug any oil feed holes in the valve gear they're there for a reason. i have tried larger than .060" and it put too much oil up top. people get concerned about starving the rotating assembly, imho this should never be an issue. if it is there's something else that's not right. remember oil does more than lubricate it also cools and cleans.
Re: BB full time rocker oiling...restrictor size... [Re: Stanton] #1335529
11/15/12 01:43 AM
11/15/12 01:43 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
going to be shocked at how the oil really only dribbles out of those holes. It will be the rocker motion flinging the oil that provides the lube to the pushrod cups. [/quote
I have a set of Hughes rockers that I blocked the tip feed. They did anything but dribble oil. They poured oil everywhere when on the drill. Blocked the tip feed holes and oil gushed out of the cup feed hole...but still burnt up cups.
Re: BB full time rocker oiling...restrictor size... [Re: JohnRR] #1335530
11/15/12 01:44 AM
11/15/12 01:44 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I'll have to measure, but it appears to be the same size as the feed hole in the head.
They are B1-BS heads..if it matters.
Re: BB full time rocker oiling...restrictor size... [Re: jamesc] #1335531
11/15/12 01:47 AM
11/15/12 01:47 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
on B1 heads
My heads are B1-BS heads. Any idea if the rocker stands are the same on the originals and the BS heads? It might be stupid question, but IDK.
Re: BB full time rocker oiling...restrictor size... [Re: Von] #1335532
11/15/12 09:55 AM
11/15/12 09:55 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Old school (but not the best) way was to run the fully grooved #4 cam bearing but install it slightly off center so the deck feed passages are ~1/2 restricted.
WIZE
In Car:
Re: BB full time rocker oiling...restrictor size... [Re: Von] #1335533
11/15/12 09:56 AM
11/15/12 09:56 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
just use oil thru push rods that have the oil restriction option
Re: BB full time rocker oiling...restrictor size... [Re: Von] #1335534
01/30/13 01:03 PM
01/30/13 01:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I believe the passage in the rocker stand is .250 and I found a welding tip is just a couple thou bigger so you can sand/file it to fit and have a pre drilled restrictor and the length only needs the edge trimmed.
Re: BB full time rocker oiling...restrictor size... [Re: Von] #1335535
01/30/13 03:24 PM
01/30/13 03:24 PM
Von, the world iron blocks have a seperate full time oil feed passage to the rocker stands, they have a .040 restrictor in them That works good
