Re: Moving battery to trunk.. how to connect the cables [Re: StandOnIt] #133538
10/10/08 12:04 AM
10/10/08 12:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
One thing to think about. If you put the battery in the trunk without the master cutoff and take it to the track at all, it will not pass tech inspection. Not even for street test and tune.
Wanna bet ?? Ron
Re: Moving battery to trunk.. how to connect the cables [Re: 383man] #133539
10/10/08 12:08 AM
10/10/08 12:08 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
It does depend on the track.
At our local track there is absolutely no way they would let you run with a batt in the trunk, and no master shutoff.
Re: Moving battery to trunk.. how to connect the cables [Re: dave571] #133540
10/10/08 12:29 AM
10/10/08 12:29 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Lots of new cars from the factory have the battery buried deep in the trunk. Do they pass tech?
Re: Moving battery to trunk.. how to connect the cables [Re: earlybee] #133541
10/10/08 12:50 AM
10/10/08 12:50 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If the car is stock with no mods yes. My old mercedes did 11.90-12.20 stock without a problem with tech. I did have to have a helmet though.
but yes it does depend on the track.
Re: Moving battery to trunk.. how to connect the cables [Re: tpabayflyer] #133542
10/10/08 12:54 AM
10/10/08 12:54 AM
So Cal
So Cal
Thanks for the info guys... I looked around for one of those borg warner #S605's and can't find a listing for it???
common part.
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=BOR&MfrPartNumber=S605
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Moving battery to trunk.. how to connect the cables [Re: HealthServices] #133543
10/10/08 01:04 AM
10/10/08 01:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have my battery in the trunk as I wanted it to look like the Max Wedge's did with the trunk mounted battery and I did not mount a cut out switch at first. I went to the track and forgot I had not put one in yet and they did not even check for it. And that was at 2 different tracks. Ron
Re: Moving battery to trunk.. how to connect the cables [Re: 383man] #133544
10/10/08 01:35 AM
10/10/08 01:35 AM
So Cal
So Cal
The track safety guys are funny. Sometimes they can be a hardazz and other times they are ok. The ones I've seen never had a check off list so it is easy to forget to look for something. Rules state if you have a gas tank in the trunk you have to have a metal firewall between the trunk and the passenger compartment. They never asked me about it but gave me a hard time about the centercaps being on the wheels.
If they see a familar car at the track they tend to just wave you on esp if they think someone checked you once before.
Re: Moving battery to trunk.. how to connect the cables [Re: HealthServices] #133545
10/10/08 06:46 AM
10/10/08 06:46 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Geezzz, our guy will kick it out in a heartbeat. One the other hand, there was a track here that would let you run with brake cables draging the ground..lol You right, may just be my track...One more question. Is there a special need for you to put it in the trunk or you just want it there? (eg, battery tray rotten. etc.)
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Moving battery to trunk.. how to connect the cables [Re: dave571] #133546
10/10/08 08:19 AM
10/10/08 08:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ditto, Ron where do you race? Capitol, 75/80 and M/D all check for an on-off switch if the battery is in the trunk
Re: Moving battery to trunk.. how to connect the cables [Re: HealthServices] #133547
10/10/08 04:48 PM
10/10/08 04:48 PM
Tampa, FL
tpabayflyer Offline OP
Tampa, FL
Thanks... I will order up a solenoid... As far as my situation goes, I don't think I need to have the trunk cutoff yet as my car is pretty mild and runs low 13's... I have only been teched once in about 10 years and thats because the track's insurance company was roaming around...
TBF
Re: Moving battery to trunk.. how to connect the cables [Re: Mr.Yuck] #133548
10/12/08 01:38 AM
10/12/08 01:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have run at Cecil and Mason Dixon. In fact this pic is from Mason Dixon and the tech guy never checked much of anything on my 63. I had the hood up and he came over and said...........is that a 426 ??? I said why yes it is and he said well then 426 is your car # today and thats about it. Ron
Re: Moving battery to trunk.. how to connect the cables [Re: 383man] #133549
10/12/08 05:17 PM
10/12/08 05:17 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Mark at MAD Electrical http://www.madelectrical.com/ has a kit that will help you with all the cables and pieces you need to hook it up right.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Moving battery to trunk.. how to connect the cables [Re: tpabayflyer] #133550
10/14/08 02:56 AM
10/14/08 02:56 AM
Indiana
P
Pentastar440 Online content
Pentastar440  Online Content
P
Indiana
Instead of using a Ford starter relay , which has no neutral safety terminal, use a Jeep relay . It looks like a Ford relay but it has an extra terminal for the neutral switch . You can get it at NAPA , Echlin # ST-83 .
As far as the starter shorting out, run a strap across the terminals on the starter , then run a cable to the ST-83 . This way the starter cable is only "hot" when the starter is engaged .
I run this setup on my '65 Belvedere .
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Moving battery to trunk.. how to connect the cables [Re: Pentastar440] #133551
10/22/08 08:13 AM
10/22/08 08:13 AM
OH
Red383 Offline
Red383  Offline
OH
As far as the starter shorting out, run a strap across the terminals on the starter , then run a cable to the ST-83 . This way the starter cable is only "hot" when the starter is engaged.
I read somewhere that it wasn't a good idea to "run a strap across the terminals on the starter" I can't remember why they said not to though.
