Can you upgrade a 69 to a better Master Cylinder?
#13353
10/06/04 08:40 AM
10/06/04 08:40 AM
Posts: 2,581 Rutherfordton NC
BarryBum
Fruit Of The Loon
Fruit Of The Loon
Rutherfordton NC
My 69 Dodge, manual brakes, has a bad master cylinder......I think. When you press the brake pedal, it goes all the way to the floor, if you pump it up, you have a little pedal but if you hold constant pressure it leaks down to the floorboard. There is no signs of leaking wheel cylinders, so it almost has to be the master cylinder. Can I upgrade to a new type (plastic type) or is there something better in the old style? And when I go to the parts store to get a different cylinder, what do I tell them it is for?
Re: Can you upgrade a 69 to a better Master Cylinder?
[Re: BarryBum]
#13354
10/06/04 09:05 AM
10/06/04 09:05 AM
Define better.
YOur stock one has many plusses. It fits without mods, it is "correct" if that matters to you, it is rebuldable and if you need to replace it or rebuild it in the future you don't have to remember what it came from.
A newer aluminum master cylinder has one benefit, it's lighter. It is not correct, rebuildable, or a bolt on.
Now on my 65 Cuda I have an aluminum M/C. Why? Because the correct, fits with no mods iron M/C is a single outlet one. Not safe. Since I have more than one MoPar I decided to run the same M/C on both. Simplify parts requirements.
Both of them do the same thing with equal ability, supply hydraulic pressure to work the brakes. Neither does it better than the other.
Steve
#13355
10/06/04 09:36 AM
10/06/04 09:36 AM
The aluminum master may not be correct, but they are in fact rebuildable AND a bolt on, except it the case of having a single line/reservour master cylinder. An aluminum master cylinder is also less prone to internal corrosion due to the anodizing of the entire part- inside and out. This also just about eliminates any wear to the bore- all of the wear is on the rubber seals.
I sell the master cylinder adapter plates as well as aluminum master cylinders, so if you need help feel free to contact me.
GregZ@Magnumhp.com
#13356
10/06/04 10:29 AM
10/06/04 10:29 AM
That might be your opinion, but it isn't shared by the factory. Ever buy a reman aluminum M/C?
Hmm, ain't there a rule against selling on this forum? I think so.
Hmm, adapter needed, that ain't "bolt on". Guess by your definition a T5 is a bolt on, only need a few adaptors.
#13357
10/06/04 11:17 AM
10/06/04 11:17 AM
Yes, and as an auto tech I've also installed a lot of them.The factory also wants you to only use factory parts. We ALL do that right?
Yes, there is, that is why i gave the offer of HELP by contacting me OFF of this forum, which is permitted.
Bolting the adapter on with the new master cylinder is no harder than mearly changing the master cylinder. It's not like you have to cut, weld, or drill.
[Re: BarryBum]
#13359
10/06/04 11:28 AM
10/06/04 11:28 AM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
I run GregZ's MC and the adapter, etc. Works good.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
[Re: 19SuperBee70]
#13360
10/06/04 11:42 AM
10/06/04 11:42 AM
BarryBum
Fruit Of The Loon
Fruit Of The Loon
Rutherfordton NC
Hey 19SuperBee70, do you have any pictures of the aluminum MC? If I decide to go with the aluminum, what do I ask for at the parts house? Because as we all know, those guys have to know the year,model, engine, tranny type, color, what station the radio is on, interior color, tire pressure and your brothers, cousins, fathers, step brothers second cousin twice removed maiden name.....before they can give you any part for any car!!!!!
[Re: BarryBum]
#13361
10/06/04 11:55 AM
10/06/04 11:55 AM
You'll need to ask for a m/c for a early 80's dodge truck with MANUAL brakes. You need to make sure it comes with the rubber pushrod retainer grommet. You also need to buy the reservour seperately. Most of the units with a res already on them will be iron .
[Re: 19SuperBee70]
#13363
10/07/04 01:29 AM
10/07/04 01:29 AM
I used one for a 79 D100, bolt on, great pedal feel and only $18 at Autozone.
#13364
10/07/04 09:54 AM
10/07/04 09:54 AM
Allow me to quote the rules to you moderator.
"Posts asking, "Where do I find...?" ARE NOT PARTS WANTED ADS! This forum has begun (once again) to turn into parts exchange central AND THAT'S NOT ITS PURPOSE!
NO MORE PARTS FOR SALE AS A RESPONSE!
E-mail & PM's are a discrete way to sell parts (yes, I've done it myself that way!) yet some of you guys are about as subtle as a kick upside the head.
UES YOUR HEADS (& E-mail!) OR RISK BEING BANNED FOR SELLING ON THE DISCUSSION BOARDS!
NO MORE PARTS ADS HERE! "
Looks like YOU are to use PM's or email to offer your services.
No, you just double, or more, the cost for no real net benefit. So you save a pound or three in weight. Some benefit for the cost. Not to mention possible pushrod issues depending on your choice of M/C and manual vs power brakes.
There is no benefit other than weight savings. Unless you are looking to save weight it is cheaper and simpler to bolt on another 4 bolt M/C in this application. If you want a firmer pedal just bolt on a larger bore M/C. Don't forget with the 2 bolt setup you still need to tweak the lines to match the relocated outlets, not a big issue but not a "bolt on" like the 4 bolt M/C is.
Steve
PS: It is cheaper to make you own adapter. That's what I did and it cost me nothing since I had a piece of scrap plate aluminum of the proper thickness lying about.
