Re: double pumper or vac.sec
[Re: gch]
#1335230
11/15/12 02:49 AM
11/15/12 02:49 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
We use a 750 DP on my sons Dart with his .030 over 400 and it works great. He uses 3.91's also and even put an 830 DP on but it ran no faster with the 830 so he went back to the 750 DP which works great for him. Just a standard 750 DP we tuned. It has run 11.40's at 117 and its just a mild 400 driver. I like the 750 DP for mild street cars. Ron
[Re: gch]
#1335231
11/15/12 08:22 AM
11/15/12 08:22 AM
Posts: 1,012 indiana
mcmopars
indiana
Borrow a known good one and find out.A 750 is the logical response but it may et better with an 800 or 850.
dont have that option
[Re: mcmopars]
#1335232
11/15/12 08:32 AM
11/15/12 08:32 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
ive always heard vac.sec with an auto for the street.
Yes for a mostly stock or mild build. With your cam, T-convertor and gears a DP should work good for you.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: mcmopars]
#1335236
11/15/12 09:32 PM
11/15/12 09:32 PM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
There used to be an old trick of putting a paperclip or something like that on the diaphragm rod to assure that the secondaries are opening completely..........
Just sayin'...........might as well make sure you're gittin' all she's got now.
[Re: Dean_Kuzluzski]
#1335237
11/16/12 10:39 AM
11/16/12 10:39 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
Yes I agree, I did that exact thing to find out the secondaries were hardly opening at all on my '28 hot rod. I had the lightest springs available, so there was nothing I could do about it. The car was just too light for the horsepower (built 468 BB Chevy) to generate enough load.
[Re: bobs66440]
#1335238
11/16/12 06:31 PM
11/16/12 06:31 PM
mcmopars
indiana
tried that a few years ago and the paper clip moved so secondaries were working
[Re: bobs66440]
#1335239
11/16/12 06:34 PM
11/16/12 06:34 PM
mcmopars
indiana
I would definitely go no more than 750. 650 would probably be good.
anyone run a 750 d.p. on a set-up simular to mine? id just really hate to over carb the thing,no returns on carbs
[Re: GTX MATT]
#1335241
11/16/12 06:39 PM
11/16/12 06:39 PM
mcmopars
indiana
The question is are they opening all the way?
how much travel should there be?
[Re: mcmopars]
#1335242
11/16/12 07:26 PM
11/16/12 07:26 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
I have a 950hp on mine, what do I know...
Cars with less cam/converter/gear run std 750dp's all the time. I wouldn't put anything smaller on it, although you could.
