Re: Anyone use Mark Williams Driveshafts?
[Re: Chris'sBarracuda]
#1335084
11/14/12 09:22 AM
11/14/12 09:22 AM
I have the moly one as well. Its a nice piece for sure. Just keep in mind its a royal blue color when you get it.Get the MWilliams pinion yoke and Spicer u joint with it. There's a reason why all the pro's use Mark Williams.Unsurpassed quality.
[Re: 451Mopar]
#1335085
11/14/12 10:23 AM
11/14/12 10:23 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have one of their "masterline" alum. shafts. I've used it about 5 years no problems, nice piece 1350 joints and yoke.
"Just a Bracket car dressed up like a streetcar"
[Re: EvilB1Dart]
#1335088
11/14/12 01:03 PM
11/14/12 01:03 PM
Posts: 23,273 Here
jcc
Here
I got a MW non welded/glued alum 3.5" with 1350's, it is a nice shaft.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: dogdays]
#1335091
11/14/12 08:09 PM
11/14/12 08:09 PM
Posts: 8,222 Plymouth, MI
Blusmbl
Plymouth, MI
Dynotech is very good too, but being local to Mark Williams I wouldn't go shopping anywhere else.
[Re: jcc]
#1335093
11/14/12 09:16 PM
11/14/12 09:16 PM
Posts: 4,329 Morrow, OH
markz528
Morrow, OH
I have one of their mild steel 4 inch shafts. Wanted to buy the 3.5 inch chrome molly and they told me I was too close to the critical speed to run a 3.5 inch shaft. My shaft is pretty long and I probably would have had the same issues as Al did.......
#1335094
11/15/12 12:36 AM
11/15/12 12:36 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I bought it, but don't have time to pick it up, so had them ship it. My old stock driveshaft vibrated, even after having it balanced, and I just replaced the 8-3/4 rear with a Strange S60 with a spool, and the 1350 moly yoke from strange, so I needed a new driveshaft that was shorter, with 1350 U-Joints, and hope it does not vibrate.
[Re: dogdays]
#1335096
11/15/12 07:18 PM
11/15/12 07:18 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
You still have to get up to Mark Williams shop and get a tour. It's worth the drive. I came away wishing I had more money
When I lived there he gave me a tour.. Awesome place.. They're head and shoulders above the rest, but not cheap..
Chris..
[Re: dogdays]
#1335097
11/16/12 03:45 AM
11/16/12 03:45 AM
451Mopar
Aurora, Colorado
Well, I guess living close has some perks, I already received the driveshaft, looks nice. I was racing King Street and Club Clash Top Street at bandimere until I broke the rocker stand on the heads (again.) My 60' times were not very good as I would launch pretty easy because the old '741 case 8-3/4 limited slip was starting to make bad noises. Nor that I have the S60 with a spool, and a bit more gear, 4.10:1 vs the old 3.91:1, I may be able to launch harder and get some traction.
