My car is needing three diffrent air pressures and I need a way to un clutter the top of my bottle. I have two regulars now and still need another but I would really like a smaller regulator then the welding unit I have now. Plus there really $$.
I have a Tee out the bottle with the welding regulator on one side and a factory set lenco shifter regulator on the other. That takes care of the shifter and transbreak. But I need one more for the boost controller. It's the thing needing the least pressure. I'd like to just Tee into the transbreak feed line and just step it down with a small regulator and not a bulky welding regulator.
