4.15 stroke HEMI #1334582
11/13/12 05:32 AM
11/13/12 05:32 AM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
I'm currently shopping for pistons to rebuild my 472 HEMI. Also looking at possibly other rods. The engine is to power my vintage NASCAR 1974 Dodge Charger racecar. So Pistons with the oil ring over the pin are a no-no. Desired compression ratio is 10.0:1 to 10.5:1 to accomodate the various fuel qualities at the different tracks that we race on. Redline is 6.500 rpm.
What brand of pistons and rod length combinationwould you recommend ?
Re: 4.15 stroke HEMI [Re: docford] #1334583
11/13/12 08:25 AM
11/13/12 08:25 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
stock length hemi rod will work fine with a 4.150 crank. I had diamond pistons make mine
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: 4.15 stroke HEMI [Re: 68 HEMI GTS] #1334584
11/13/12 08:56 AM
11/13/12 08:56 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
As stated, stock length 6.86 rod, preferably a Manley with .990" pins. Similar to the set-up I run with JE pistons at 484 cubes, although I am running 11.6:1 on pump gas and shift closer to 7k...
Re: 4.15 stroke HEMI [Re: docford] #1334585
11/13/12 10:46 AM
11/13/12 10:46 AM
gregsdart Offline
gregsdart  Offline
I run Cp pistons in my motor, custom made. There are other good custom piston makers out there also. I see a lot of room for improvement on that piston/ring/rod setup. If rules allow, anything you can do to reduce rotating weight will help you out. 2.2 rod journals, move the ring pack up tighter to the top, coat the pistons like a Gen III Hemi to keep the rings cool, possibly go to a narrower ring, and finally once you figure out just how far you can move things, the longest rod you can put in the motor to make the piston as light as possible. If you have some flexibility within the rules, then the first thing to do is talk to a custom piston manufacturer and see what they can do for your setup. Rods are available in 7.1 inch long H beams with the smaller 2.2 bearings. There may be longer ones out there. That will leave you enough room for the rings along with some serious weight reduction as you still would have a piston pin compression height of 1.55 for a 10.725 deck height.
EDIT; I just looked at the OLIVER connecting rods web site and they custom make rods to your needs. Pricy, but they are about the best rod made.
Re: 4.15 stroke HEMI [Re: docford] #1334586
11/13/12 02:55 PM
11/13/12 02:55 PM
Harrison Township, Michigan
Hemi SS Offline
Hemi SS  Offline
I have a 4.150 stroke with 2.200 rod journals. I used a 7.100 rod with .990 pins and had Diamond make pistons. Plenty of room between pin and oil ring.
Re: 4.15 stroke HEMI [Re: Hemi SS] #1334587
11/13/12 03:41 PM
11/13/12 03:41 PM
Dragula Offline
Dragula  Offline
My next one I want to do this way....
Re: 4.15 stroke HEMI [Re: Hemi SS] #1334588
11/13/12 03:44 PM
11/13/12 03:44 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I used Diamond pistons on my 4.15/6.86.. 477. CompetitionWedge supplied them and went with 9 1/2 cr because of gas, less weight(?) and decked block. Compression works out to about 10.97 to 1!
Rods are 440source
Re: 4.15 stroke HEMI [Re: 52savoy] #1334589
11/13/12 04:05 PM
11/13/12 04:05 PM
Dragula Offline
Dragula  Offline
Rods are 440source
Diamond will also probably get my next order as well for Hemi pistons. They have some really nice dedicated hemi stuff with comparable prices. We have built at least one hemi with their pistons, and they are nice and light. The JE's I have are quite a bit heavier.
Re: 4.15 stroke HEMI [Re: Dragula] #1334590
11/13/12 05:13 PM
11/13/12 05:13 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
I'm using stock length K1 billet rods and ICON forged pistons in my 477.
Re: 4.15 stroke HEMI [Re: Dragula] #1334591
11/13/12 05:26 PM
11/13/12 05:26 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I switched from JE to Diamond on my 472" and really liked them. I changed from NASCAR 6.96" rods to Eagle 6.86". This is not a race engine though. I like the 7.100 rod and 2.20 journal idea, and would definitely look at Diamond pistons.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 4.15 stroke HEMI [Re: Hemi Allstate] #1334592
11/14/12 07:23 PM
11/14/12 07:23 PM
dogdays Offline
dogdays  Offline
There is a pair of Carrillos on the 'bay right now, BBC sizes for wrist and rod journal, 7.25" long.
But there are just two.
Anyway, longer than 7.100" rods can be had.
R.
Re: 4.15 stroke HEMI [Re: dogdays] #1334593
11/15/12 03:51 PM
11/15/12 03:51 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
So now we got the HEMI apart. The rods are 7.1" long and from Oliver . The Pistons are 4.28" bore from JE. The crank is in fact a 4.50" stroke and notna 4.15". Sorry fro the wrong info but I was told that it is a 472 when I bought it.
Re: 4.15 stroke HEMI [Re: Hemi Allstate] #1334594
11/15/12 03:57 PM
11/15/12 03:57 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
the weak point of the pistons right now is that the lower support of the oil ring is half way milled away to clear the piston pin. I'll ask JE if they can move the whole ring set up about 1/16th so there would be more meat under the oil ring
Re: 4.15 stroke HEMI [Re: docford] #1334595
11/15/12 08:27 PM
11/15/12 08:27 PM
dogdays Offline
dogdays  Offline
Unless you have a cubic inch limit I'd say you got lucky.
Those giant Oliver billet rods are he77 for stout.
I have been buying part-used-up racing gear for the past few months and roughly half of the pistons have support rings under the oil ring because the pins are in the oil groove. If it's good enough for Sonny Bryant and Rousch Racing it's good enough for me!
As a side note, I have a half a set of Crower 7.1s with 4.360 diameter pistons that came out of a ford 460, I bought them for the rods. The rod/piston/pin/ring set weighs just a little more than 100 grams more than the bone stock rod/pin/piston/ring set from a stock 318!
I think some of the extremely conservative ideas found among Mopar lovers come from the unconscious attempt to justify the grossly overweight parts found in garden variety Chrysler Corp engines.
R.
Re: 4.15 stroke HEMI [Re: docford] #1334596
11/15/12 10:54 PM
11/15/12 10:54 PM
tn
robnbird Offline
robnbird  Offline
tn
JE or Wiseco pistons for me I had a bad experience with Diamond and a set of Indy heads and refuse to ever use Diamond, no thanks,,, JE however I have used without a flaw ever.. plus wiseco are excellent... just my 2 cents
Re: 4.15 stroke HEMI [Re: docford] #1334597
11/15/12 11:00 PM
11/15/12 11:00 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
JE and Oliver sound good to me. Are you just going to freshen and screw it back together now?
Sheldon
Re: 4.15 stroke HEMI [Re: RUNCHARGER] #1334598
11/15/12 11:23 PM
11/15/12 11:23 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Sheldon
That's what I was thinking too. A 518" Hemi makes for a pretty stout round track motor, even if it was 9 to 1 compression.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: 4.15 stroke HEMI [Re: RUNCHARGER] #1334599
11/16/12 06:14 PM
11/16/12 06:14 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
Sheldon
We might go to 4.29" or 4.31" oversize. Two pistons got burned bad when the fuel pressure dropped at full speed in fourth and Me idiot did not lift off the throttle as I wanted to catch that Renault in front of me so bad !! Bummer
Re: 4.15 stroke HEMI [Re: 23T Hemmee] #1334600
11/16/12 06:18 PM
11/16/12 06:18 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
Sheldon
Oh yes indeed and a drop in compression from currently 11.7:1 to 10.5-10.9:1 is also on the list of to do things. So pistons will be ordered with less dome.
Camshaft is Racer Brown roller with 276°@050 and .629 lift with 1.6 rockers. Would you suggest another roller cam since we are droppig compression ?
Re: 4.15 stroke HEMI [Re: docford] #1334601
11/16/12 10:50 PM
11/16/12 10:50 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
[quote Would you suggest another roller cam since we are droppig compression ?
Kind of hard to say, not knowing the car weight, the type of tracks you're running on, and how much RPM drop in the turns. Doubt there is going to be a "one size fits all" cam, although with that many cubes, it probably isn't going to be quite as critical. Back in the day,('66-68 or so) the NASCAR Hemi's were running the equivalent of the old Racer Brown STX-24 on the big tracks (around .590" lift and 328 total duration) and STX-22 on short tracks (same lift at 312 degrees duration, at least my fading memory tells me that). Not sure how they would equate to the @.050" method but thats just to give you a ball-park comparison. BTW the cars back then were in the 3900lb. range, not sure what yours weighs.
Ronny
John 14:6
