4 Speed help needed
#1334271
11/12/12 01:07 PM
11/12/12 01:07 PM
Posts: 2,648 GA
Boosted
GA
The front bearing has gone out on the 833. How can I change just this bearing without a complete tear down?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: 4 Speed help needed
[Re: fourgearsavoy]
#1334276
11/13/12 12:51 AM
11/13/12 12:51 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I have successfully replaced a front bearing before using a combination of different puller parts.You need a good selection of quality puller jaws and parts of a differential side bearing puller.Now that you have the bearing off it's time to slowly drive the new bearing on with an air chisel with a blunt round tip on it.Dial down the power to almost the lowest setting and SLOWLY and CAREFULLY drive it onto the shaft.Make sure it's completely seated and re-install the snap rings and the bearing retainer. Not for the beginner but it can be done
I would bet the average joe could do it faster the right way (not to say yours is the wrong way).
[Re: fourgearsavoy]
#1334277
11/13/12 02:14 AM
11/13/12 02:14 AM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
I have successfully replaced a front bearing before using a combination of different puller parts.You need a good selection of quality puller jaws and parts of a differential side bearing puller.Now that you have the bearing off it's time to slowly drive the new bearing on with an air chisel with a blunt round tip on it.Dial down the power to almost the lowest setting and SLOWLY and CAREFULLY drive it onto the shaft.Make sure it's completely seated and re-install the snap rings and the bearing retainer. Not for the beginner but it can be done Gus
I did it when I was 17/18, when I didn't know any better, with hand tools , it can be done though I don't think I would try it now. Someone mentioned an OD833 , the bearings on those come off almost by hand , very light press fit , I have taken them booth off with little effort and a big pair of screw drivers.
