Page 1 of 3 1 2 3
Drag Week 2013 Hemi on Dyno #1334119
11/12/12 01:10 AM
11/12/12 01:10 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
Reached a long awaited milestone in my Hemi build this week. After collecting parts and slowly progressing through the build for the past year and a half, the engine finally found its way to the dyno cell last week. I had hoped to run the engine in 2012, but the schedule did not work out. I am now targeting 2013 to have engine and car at Drag Week.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334120
11/12/12 01:15 AM
11/12/12 01:15 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
The engine is a normally aspirated 588 and is designed for extended street use. Valve lift is under .690, cranking compression is 160#. Dyno headers are 2 1/8" Super Comps. All testing was done with pump gas from the local Speedway gas station.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334121
11/12/12 01:21 AM
11/12/12 01:21 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
More compression, cam, headers, and a different intake would probably improve the power, but I wanted reliability and a lower scoop profile for the street.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334122
11/12/12 01:43 AM
11/12/12 01:43 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Nice! So what car is it in and what class are you running?
This post is available in double vision where drunk.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334123
11/12/12 01:43 AM
11/12/12 01:43 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
That's going to be serious fun on the street.....
Re: Drag Week 2013 Hemi on Dyno [Re: bwdst6] #1334124
11/12/12 01:48 AM
11/12/12 01:48 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
The engine is going into a 67 Belvedere chassis. I plan to run in the Street Race class, big block normally aspirated category.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334125
11/12/12 02:52 AM
11/12/12 02:52 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Isnt that the class Bill Fowler runs in?Better check the rules as you may need a straw hat to enter.
Re: Drag Week 2013 Hemi on Dyno [Re: ksj] #1334126
11/12/12 08:46 AM
11/12/12 08:46 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That is a nice combo! Are you allowed a tanker trailer with fuel? Curious what lifters and valve springs you're using?
Re: Drag Week 2013 Hemi on Dyno [Re: 72Swinger] #1334127
11/12/12 09:49 AM
11/12/12 09:49 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I believe you could have made more power with a smaller port. The velocity must have been low.
Re: Drag Week 2013 Hemi on Dyno [Re: Defbob] #1334128
11/12/12 10:37 AM
11/12/12 10:37 AM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
Yep, it was way down on power due to the ports, probably would have been 1150 instead of "only" 1054.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334129
11/12/12 11:19 AM
11/12/12 11:19 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Drag Week 2013 Hemi on Dyno [Re: BBR] #1334130
11/12/12 01:56 PM
11/12/12 01:56 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Are those millineum heads?
2011 Drag Pak Challenger
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334131
11/12/12 02:53 PM
11/12/12 02:53 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Scott I really hope you make it out for the 2013 DW. I do have a question about your AWESOME HEMI build, How much cam are you runing? Do you use pushrod oiling with the Barton Rocker Arm setup? If not, how well do they live on the street. The only reason I am asking, I was going to buy a used setup from a SS racer and he said they were not recommended for long runs or street use since they had such limited oiling.
Thanks for the input and Good luck.
Old Geezer Racing
Re: Drag Week 2013 Hemi on Dyno [Re: SCATPACK 1] #1334132
11/12/12 10:07 PM
11/12/12 10:07 PM
Indiana
Scott58 Offline OP
Scott58  Offline OP
Indiana
Lifters are Comp 98829's. Heads are Stage V Millenniums. Cam is about 280 @ .050 at about .685 lift on intake. The spray oiling remains to be proven on the street, but I think 572Charger has used this setup quite a bit on the street with no problems. There is really quite a bit of spray up in the valve covers at pressure. I'll be watching it closely while driving the car next year during testing, if necessary we will add some oil to the top end, either via pushrods or more spray.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334133
11/13/12 07:30 PM
11/13/12 07:30 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I apologize, I realize I misread the chart. I saw the "821 HP" and thought it was the peak HP. My mistake.
Re: Drag Week 2013 Hemi on Dyno [Re: Defbob] #1334134
11/13/12 08:32 PM
11/13/12 08:32 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I thought the same thing...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Drag Week 2013 Hemi on Dyno [Re: Sledge_57] #1334135
11/13/12 08:43 PM
11/13/12 08:43 PM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
Has anyone heard any rumors on where Drag Week will actually be held next year?
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334136
11/13/12 09:09 PM
11/13/12 09:09 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I mis-read the chart also lol, those are great numbers, that will be an amazing pump gas street motor.
With the design of the upper portion of your intake, will it need any kind of blow out window?
I just wondered as it looks similar to some of those intakes that have a tendancy to go boom during fire up, unless its different than what I'm thinking of.
Re: Drag Week 2013 Hemi on Dyno [Re: Scott58] #1334137
11/13/12 09:41 PM
11/13/12 09:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Wish I could afford a car that an engine like that would work in. Lots of details to work out on an engine like that...really cool..Very sweet build for sure. How many cubes is that thing that you are running two SV1's?
Also, I know Jim Paranis (572Charger) personally, and he does drive his 605 on the street....
Re: Drag Week 2013 Hemi on Dyno [Re: bwdst6] #1334138
11/13/12 09:42 PM
11/13/12 09:42 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
i heard they are doing it in England this year... so Larson and Lutz can hand Andy Frost his asss
Page 1 of 3 1 2 3
