Drag Week 2013 Hemi on Dyno
#1334119
11/12/12 01:10 AM
11/12/12 01:10 AM
Posts: 174 Indiana
Scott58
Indiana
Re: Drag Week 2013 Hemi on Dyno
[Re: Scott58]
#1334122
11/12/12 01:43 AM
11/12/12 01:43 AM
Posts: 970 Backwater, PA
bwdst6
Bob George Racing #1 Fan
Backwater, PA
Nice! So what car is it in and what class are you running?
This post is available in double vision where drunk.
[Re: ksj]
#1334126
11/12/12 08:46 AM
11/12/12 08:46 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That is a nice combo! Are you allowed a tanker trailer with fuel? Curious what lifters and valve springs you're using?
[Re: Scott58]
#1334131
11/12/12 02:53 PM
11/12/12 02:53 PM
Posts: 1,505 TN
SCATPACK 1
TN
Scott I really hope you make it out for the 2013 DW. I do have a question about your AWESOME HEMI build, How much cam are you runing? Do you use pushrod oiling with the Barton Rocker Arm setup? If not, how well do they live on the street. The only reason I am asking, I was going to buy a used setup from a SS racer and he said they were not recommended for long runs or street use since they had such limited oiling. Thanks for the input and Good luck.
Old Geezer Racing
[Re: Scott58]
#1334133
11/13/12 07:30 PM
11/13/12 07:30 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Yep, it was way down on power due to the ports, probably would have been 1150 instead of "only" 1054.
I apologize, I realize I misread the chart. I saw the "821 HP" and thought it was the peak HP. My mistake. ![](/ubbthreads/images/graemlins/blush.gif)
[Re: Sledge_57]
#1334135
11/13/12 08:43 PM
11/13/12 08:43 PM
bwdst6
Backwater, PA
Has anyone heard any rumors on where Drag Week will actually be held next year?
[Re: Scott58]
#1334136
11/13/12 09:09 PM
11/13/12 09:09 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I mis-read the chart also lol, those are great numbers, that will be an amazing pump gas street motor.
With the design of the upper portion of your intake, will it need any kind of blow out window? I just wondered as it looks similar to some of those intakes that have a tendancy to go boom during fire up, unless its different than what I'm thinking of.
[Re: bwdst6]
#1334138
11/13/12 09:42 PM
11/13/12 09:42 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
i heard they are doing it in England this year... so Larson and Lutz can hand Andy Frost his asss
