Re: cutting Ross piston for valve clearance
[Re: Plymouth340]
#1334108
11/12/12 01:20 AM
11/12/12 01:20 AM
Posts: 43,173 Bend,OR USA
Cab_Burge
Got a small block with a 630 roller cam and .090 piston to valve clearance on intake and exhaust and would like to go bigger cam. like maybe 700 lift. can these piston be cut for valve clearance that much or do i need new pistons? has a 3.79 stroker crank and ross pistons..6.123 rods
Get the new cam and installed it by the cam makers specs and then check the piston to valve clearances Roller cam lobes are designed to work well, I have had roller cams fit in motors that a similar solid lifter cam wouldn't fit in do to piston to valve clearances. I do use .050 intake valve to piston and .080 exhaust valve to piston clearances as my goal when using light checking springs Cam grinders recommend what they think will keep you from blaming them for the valves hitting the pistons I use 240 to 325 lbs on the seats and from 600 lbs to 850 lbs open also, with really good valves, pushrods, keepers, lash caps rocker arms, and retainers
[Re: Cab_Burge]
#1334109
11/12/12 01:34 AM
11/12/12 01:34 AM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
thanks..its a running motor and dont really want to go to all that work if it aint going to fit..but it would be nice if it did..hows them rocker stands i sent you work out?
[Re: Plymouth340]
#1334110
11/12/12 02:09 AM
11/12/12 02:09 AM
Cab_Burge
There in my cabinet waiting for the next project that may need them Probally a set of aluminum heads with M.W. ports with a broken rocker shaft pedestal Thanks again, Cab
[Re: LaRoy Engines]
#1334113
11/12/12 02:52 PM
11/12/12 02:52 PM
Plymouth340
CEDAR RAPIDS
Remember also that just because you go another .070" lift, it doesn't mean your piston to valve clearance will change .070". I don't remember for sure but it seems like it may be more like .010-.020"
i talked to ross pistons and they said i cant cut much off the pistons i have now but talking to other people if i get the right cam with a widened lobe seperation i could probaly get a bigger roller to work. may call comp cams and see what they say,,,,
[Re: Plymouth340]
#1334114
11/12/12 04:51 PM
11/12/12 04:51 PM
Guitar Jones
You did the right thing by calling Ross. Most light weight pistons don't have much room to cut anything deeper. If you need deeper reliefs you need to order them with the pistons.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Plymouth340]
#1334115
11/12/12 05:55 PM
11/12/12 05:55 PM
Posts: 4,206 New York
polyspheric
New York
I'd ask Ross for a dimensioned drawing of the piston dome in both plan and elevation. You want to know where the bosses are, and the contour of the underside of the dome. The maximum depth of a notch is not absolute, but varies greatly between the center of the piston and directly over a pin boss, as well as the local temperature etc. The same depth of intake notch to the boss is far safer then an exhaust notch to the ring land.
Boffin Emeritus
[Re: polyspheric]
#1334116
11/12/12 06:49 PM
11/12/12 06:49 PM
Guitar Jones
It's going to be the intake notch to the top ring land that's the problem.
[Re: Plymouth340]
#1334117
11/12/12 09:25 PM
11/12/12 09:25 PM
Posts: 2,859 Pattison Texas
CSK
Pattison Texas
when you advance the cam the intake valve gets closer & ex gets further,you can retard the cam to get more clearance ,but may lose some lower rpm hp
[Re: CSK]
#1334118
11/12/12 09:30 PM
11/12/12 09:30 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Call Eric at RebCo machine in Wichita KS. You can find his website on google.
He cut a set of Ross BB pistons for me. I needed the valve pockets increased to lower comp for pump fuel. The valve pockets started out at 7cc, he cut them to 14cc.
He sonic checks all parts of the piston and tells you what he can and cant do. He made mine a little thin for nitrous use. I wasnt terribly upset, cause the block will split anyway...if it melts a piston first, oh well....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
