Switching from Valvoline VR1 to Brad Penn: suggestions? #1333974
11/11/12 06:58 PM
11/11/12 06:58 PM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
I'm planning on changing the oil in my street/strip 440 (flat tappet) engine in a few weeks and I'm thinking about going with the Brad Penn 15/40W partial synthetic oil. I've never used any partial synthetic oils (previously have used VR1)...anything I should know before making the switch?
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Switching from Valvoline VR1 to Brad Penn: suggestions? [Re: 1968RR] #1333975
11/11/12 07:05 PM
11/11/12 07:05 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I use 20/50 Brad Penn with a bottle of Hughes Engine additives
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Switching from Valvoline VR1 to Brad Penn: suggestions? [Re: Wicked49670dart] #1333976
11/11/12 07:18 PM
11/11/12 07:18 PM
s.e. michigan
top8x7b Offline
top8x7b  Offline
s.e. michigan
You will love it ,been using it in my race motors with flat tappet cams on alcohol ,without additives
Re: Switching from Valvoline VR1 to Brad Penn: suggestions? [Re: 1968RR] #1333977
11/11/12 07:31 PM
11/11/12 07:31 PM
Az
Crizila Offline
Crizila  Offline
Az
Go to a full synthetic such a Royal Purple racing oil - 10W40. You won't need an additive ( zinc built in ). You will be able to run a lower viscosity ( reads less friction loss ) with the same protection and improved heat degradation capabilities.
Fastest 300
Re: Switching from Valvoline VR1 to Brad Penn: suggestions? [Re: Crizila] #1333978
11/11/12 09:43 PM
11/11/12 09:43 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Valvoline NFS already has loads of zinc and phosporous. That is my choice.
Leon
