Cop steering box, 80 R-Body to 73 C-Body? #1333748
11/11/12 04:25 AM
11/11/12 04:25 AM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
Hey all,
I have a firm feel box off an '80 R-Body cop car. Had it for awhile now. Will this box work with my '73 Fury. IIRC its the same except the pitman arm.
Will the 73 arm bolt up to this box?
Also, will the PS lines be metric? I have the early saginaw pump (oval neck) and thought about robbing the brackets and later pump off a mid 80s 5th ave if it were a metric box. Or will the metric lines and fitting on the back of the pump interchange from the later pumps?
I plan on adding washers to de-pressurize the pump in the process. Can this be done with the early saginaw pumps?
Any help appreciated.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Cop steering box, 80 R-Body to 73 C-Body? [Re: MoPar Jamie] #1333749
11/11/12 04:31 AM
11/11/12 04:31 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Hey all,
Yes.
No.
Should. The mid 80's stuff should not be metric.
Should be the same. Re-Check the Mopar Action Richard Ehrenberg article though.
Re: Cop steering box, 80 R-Body to 73 C-Body? [Re: MoPar Jamie] #1333750
11/11/12 10:30 AM
11/11/12 10:30 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Total bolt-in.
You can reduce the line pressure on any Saginaw pump, Metric or not.
Rick
Re: Cop steering box, 80 R-Body to 73 C-Body? [Re: Rick_Ehrenberg] #1333751
11/12/12 12:19 AM
11/12/12 12:19 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
How do you shim what to reduce the pump pressure? Is this to hep get a little more road feel
Re: Cop steering box, 80 R-Body to 73 C-Body? [Re: HotRodDave] #1333752
11/12/12 05:03 PM
11/12/12 05:03 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Yup, helps eliminate that over-boosted, zero-effort feel.
Mopar Action
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
