venturi size of 850 and 950 holley? #1333638
11/10/12 11:58 PM
11/10/12 11:58 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone know the venturi sizes for 850 and 950? just curious here as i have what bigs performance calls a 950 stage 5+,but the main body is stamped 850 and has 1.400 venturi's.
Re: venturi size of 850 and 950 holley? [Re: mopar dave] #1333639
11/11/12 12:01 PM
11/11/12 12:01 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I'm just going off memory but I think that the Holley 950's are 1.38 and their 850's are 1.56. I never "got" the 950 rating based on that.
Re: venturi size of 850 and 950 holley? [Re: B1MAXX] #1333640
11/11/12 12:05 PM
11/11/12 12:05 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
you're correct on size. the 950cfm rating is bogus.
Re: venturi size of 850 and 950 holley? [Re: lewtot184] #1333641
11/11/12 12:29 PM
11/11/12 12:29 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quoteyou're correct on size. the 950cfm rating is bogus.
Or is the 850cfm rating bogus? Or is the 1000 cfm rating bogus on the HP carbs which have the same size venturis and throttle plates as the 4781 850s??
Or should all CFM ratings be taken with a grain of salt?
The 950 PF main body venturis are smaller than the Holley 950 main body.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: venturi size of 850 and 950 holley? [Re: Von] #1333642
11/11/12 12:35 PM
11/11/12 12:35 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Dave....these guys are correct.....
Old style 850 Holley are 1.560 Venturi X 1.750 Butterfly
Holley List #80496 950 1.375 Venturi X 1.750 Butterfly
On our 950 Stage 5 we keep the venturi at the stock 1.375
and on our Stage 5 950 Plus carb we open the venturi up to 1.400 by opening up the customers HP body or we also will use the Proform "850" body which already has the venturi at 1.400..
Hope this helps...Jesse
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: venturi size of 850 and 950 holley? [Re: Von] #1333643
11/11/12 01:24 PM
11/11/12 01:24 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i believe all the HP ratings are inflated. the older vacuum secondary and double pumpers are closer to their ratings. i don't pay much attention to cfm ratings. it's just a marketing ploy that the buying public has taken hook, line, & sinker. it's easier for most people to take the manufacturer's rating as gospel than to dig into the statistics of the product and make an informed decision.
Re: venturi size of 850 and 950 holley? [Re: lewtot184] #1333644
11/11/12 02:01 PM
11/11/12 02:01 PM
western PA
Sb Valiant Offline
Sb Valiant  Offline
western PA
Most people that run 850 say they are going to step up to a 950 cfm carb the following year well what some people don't know is it's actually a smaller carb and has more cfm. The point is You can make a big carburetor small but you can't make a small carburetor big. Naturaly the 950 just works better.
Re: venturi size of 850 and 950 holley? [Re: Sb Valiant] #1333645
11/11/12 02:36 PM
11/11/12 02:36 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
The 950/1000 HP hollers are a marketing ploy from Holley. Their 750
Carbs tested at a higher pressure that's it. Their a lie
74 dart sport 440 www.Csucarbs.com
Re: venturi size of 850 and 950 holley? [Re: shoebox] #1333646
11/11/12 05:44 PM
11/11/12 05:44 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
The same for Barry Grant stuff, the CFM ratings are different for the same size carbs
Re: venturi size of 850 and 950 holley? [Re: mopar dave] #1333647
11/11/12 06:27 PM
11/11/12 06:27 PM
AndyF Online content
AndyF  Online Content
A 1.40 is a fairly small venturi carb. Works well with smaller engines, or lower engine speeds. Nothing wrong with a 1.400 carb, you just need to match it up to the correct engine. Holley now has a 1.590 venturi in the new aluminum carbs. That carb really makes the power on a big engine.
Re: venturi size of 850 and 950 holley? [Re: AndyF] #1333648
11/11/12 06:55 PM
11/11/12 06:55 PM
Mt Morris Michigan
Mt Morris Michigan
ok,so with 1.400 venturi and a 1 3/4 blade my carb would be closer to what size carb? 800?
Re: venturi size of 850 and 950 holley? [Re: emarine01] #1333649
11/11/12 07:04 PM
11/11/12 07:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It would be nice to see actual flow data using a standardized method conducted at several different differential pressures, say .5 to 2.0 "hg.
Venturi size is not necessarly the defining element for air flow. There are several aspects that will effect the flow. Slight changes in shape and contours can have a large impact on air flow.
Another item of note is that on my 4781, the boosters are different than on my 950. They are thicker and look like they would be more restrictive to flow.
With all that, it is hard to believe that the 950 (1.375" venturi) flows more air than the 4781. However, on my car, the 950 is 1 mph faster, and .2 sec quicker.
Re: venturi size of 850 and 950 holley? [Re: BSB67] #1333650
11/11/12 07:20 PM
11/11/12 07:20 PM
Mt Morris Michigan
Mt Morris Michigan
Just tryin to figure out what my carb is simular to in holley size wise so i can look at stock jetting. Went to the track with 76/84 jetting and put 82/90 jets with a new 4.5pv and it liked this time. Never liked it before.
Re: venturi size of 850 and 950 holley? [Re: mopar dave] #1333651
11/11/12 07:26 PM
11/11/12 07:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My low et in cool air was 77/84 in my 950.
Re: venturi size of 850 and 950 holley? [Re: BSB67] #1333652
11/11/12 07:42 PM
11/11/12 07:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
for me, knowing your engine and car, the smaller carb may have created a torque advantage thru the power band. i also thought the smaller carb had some a/f issues. did that get resolved?
Re: venturi size of 850 and 950 holley? [Re: BSB67] #1333653
11/11/12 07:42 PM
11/11/12 07:42 PM
Mt Morris Michigan
Mt Morris Michigan
And thats on a 500ci? I thought their was something not quit right with my jetting. Almost like the power valve is not opening.
Re: venturi size of 850 and 950 holley? [Re: mopar dave] #1333654
11/11/12 08:36 PM
11/11/12 08:36 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I thought the smaller venturi on the 950, made for a better shift recovery.
Andy, what exactly do you mean by a larger engine.
500 and up ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: venturi size of 850 and 950 holley? [Re: lewtot184] #1333655
11/11/12 11:34 PM
11/11/12 11:34 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Still rich in transition.
Re: venturi size of 850 and 950 holley? [Re: deaks] #1333656
11/11/12 11:36 PM
11/11/12 11:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
500 and up ?
Mick
That is where it made the most difference on mine - shift recovery
