SB Mopar Rear Main oil leak #133354
10/07/08 09:44 AM
10/07/08 09:44 AM
Empire Michigan
Taconite Offline OP
Taconite  Offline OP
Empire Michigan
I have been having issues with an oil leak since I had my motor built a several years ago. My motor a SB 340 seems to be leaking out of the rear main area. I have replaced the rear main seal 3 times. I know that this is being installed properly and the correct direction. I called the engine builder and they said to try a 455 Buick rope seal which I tried with no success either.
I pulled the motor out again and pulled off the rear main cap and I was thinking that the oil might be coming out of the mating surfaces between the oil pump and the block. Has anyone every seen this before? Any one have any ideas of how to fix this? Thanks for any ideas in advance.
Re: SB Mopar Rear Main oil leak [Re: Taconite] #133355
10/07/08 10:09 AM
10/07/08 10:09 AM
Jax, Florida
1976duster Offline
1976duster  Offline
Jax, Florida
I had the same problem. When I took the oil pump off I found some high spots on the engine side mating surface. I used a flat file and filed it down. youed be surprised how uneven the surface is when you take a few light passes of the file.
I then put it back together and no more problems.
(I took my oil pan off 4 different times)
Re: SB Mopar Rear Main oil leak [Re: Taconite] #133356
10/07/08 10:22 AM
10/07/08 10:22 AM
The first thought that comes to my mind is a nick or scratch on the seal surface of the crank. Any oil that would leak between the pump/main cap surface should just spill back into the pan.
Did you use a small dab of RTV at the seal ends when you reinstalled the main cap?
Sid
Re: SB Mopar Rear Main oil leak #133357
10/07/08 10:51 AM
10/07/08 10:51 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
are you using the 3 piece oil pan gasket or the one piece?
Re: SB Mopar Rear Main oil leak [Re: Taconite] #133358
10/07/08 11:03 AM
10/07/08 11:03 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I had what i thought was a rear main leak a few years ago..pulled pan off with motor in car, rplaced seal, still leaked, pulled pan off again, rope seal, still leaked.
Finally took car and got it on a lift, pulled tranny out, the big cam plug was leaking, replaced and that was it, could see a little oil just standng in the bottom of the plug. it would run down the back of the block and look exactly like a rear main...just a thought
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: SB Mopar Rear Main oil leak [Re: B3422W5] #133359
10/07/08 04:33 PM
10/07/08 04:33 PM
Empire Michigan
Taconite Offline OP
Taconite  Offline OP
Empire Michigan
I can take some photos too.
I am using the 4 pcs gasket. Front, rear, and 2 sides. Does someone make a 1 pcs? I know that they do for a 360.
I have replced the pan and every time I replaced the Rear Main seal I put a dab of sealant in between the cap and the block.
I will check it out so see if something is holding it up like a small burr or something.
I will check out the cam plug. But, I doubt that it is leaking there but I will take a hard look because the engine is on a stand.
Another thing that I was thinking is putting it back together after checking all of the above and priming it to see if it still leaks.
I just want this to stop. I leave a puddle every where I go not to mention the garage.
Re: SB Mopar Rear Main oil leak [Re: Taconite] #133360
10/07/08 04:58 PM
10/07/08 04:58 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I just went through this horror show.... I had to remove the headers and motor mounts and hoist the engine up as high as it could go to get enough clearance to get the pan out..... I had a pretty bad leak and I used a gasket kit for a late model magnum engine and I have a 70 318 block.
I replaced the rear main seal with the correct seal with the "ears" and it seems to be doing alot better but I did notice some oil leaking from the right angle oil filter adapter. I am going to get rid of it hope that solves all my oil leaks.... here is a pic of the 2 different seals...
TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: SB Mopar Rear Main oil leak [Re: tpabayflyer] #133361
10/07/08 05:01 PM
10/07/08 05:01 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
block side view..... I have an 83 J-body... TBF
Re: SB Mopar Rear Main oil leak [Re: tpabayflyer] #133362
10/07/08 05:07 PM
10/07/08 05:07 PM
offset your rear main by about 1/4" in the slot. to do that, you'll cut those ears off the car seal. cut them flush to the back of the seal. You still use those ears and just butt them up against the rear main seal sticking up. still use RTV on the ends of the seal and a layer on the cap mating surface where the ears are.
I had a leak as well, thought it was the rear main- found out the oil pan gasket had split. the rear main sealed great
Re: SB Mopar Rear Main oil leak #133363
10/08/08 01:34 PM
10/08/08 01:34 PM
Empire Michigan
Taconite Offline OP
Taconite  Offline OP
Empire Michigan
Here are (2) pictures of mine.
Re: SB Mopar Rear Main oil leak [Re: Taconite] #133364
10/08/08 01:35 PM
10/08/08 01:35 PM
Empire Michigan
Taconite Offline OP
Taconite  Offline OP
Empire Michigan
# 2
Re: SB Mopar Rear Main oil leak [Re: Taconite] #133365
10/08/08 01:38 PM
10/08/08 01:38 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
There has not been excessive crankcase pressure in any of these case has there? Make sure your pcv is working properly and also try liftine the dipstick out just a bit and see if leak slows.
Re: SB Mopar Rear Main oil leak [Re: wheelsup68dart] #133366
10/08/08 02:00 PM
10/08/08 02:00 PM
Empire Michigan
Taconite Offline OP
Taconite  Offline OP
Empire Michigan
I have a K and N Air Breather on one of my valve covers so I would assume that I do not have excess crank case pressure.
Re: SB Mopar Rear Main oil leak [Re: Taconite] #133367
10/08/08 02:39 PM
10/08/08 02:39 PM
but do you have a pvc on the other valve cover?
Re: SB Mopar Rear Main oil leak #133368
10/08/08 02:52 PM
10/08/08 02:52 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
excessive crankcase pressure is more likely to blow the oil pass the rear pan seal and not the rear main seal... the rear main seal will be under pressure from the oil pump...
Tony
70 AARCuda Vitamin C
Re: SB Mopar Rear Main oil leak [Re: 70AARcuda] #133369
10/08/08 03:07 PM
10/08/08 03:07 PM
scratchnfotraction Offline
that part of the crank can be worn and a seal no longer can seal on it also
like rod bearings..std,.010,.020 over size
put a mic on the crank and see if its still in specs
and lube the seal with oil so its not a dry start,and burn the rubber
Re: SB Mopar Rear Main oil leak [Re: scratchnfotraction] #133370
10/08/08 07:27 PM
10/08/08 07:27 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i just tonight found that problem. the Mr. gasket kit doesn't have the seal with the ears molded on like the felpro. they just include the two pieces. mine was lealing like he** too. so i was looking at some pieces i had left in a felpro kit. and there was the seal with the ears molded on. i will be getting a new pan tomporrow. i bet that was the leak. doesn't look like u have the seal with the ears as in the above pic. 360s don't use that both seals are the same. no more Mr. gasket stuff for me.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: SB Mopar Rear Main oil leak [Re: tpabayflyer] #133371
08/01/10 06:49 PM
08/01/10 06:49 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
TBF
I am going to install the magnum seal (4798216AC) as recommended in Larry Shepard's book (how to hot rod mopar small block). It is the same as in your picture but I beleive you had it installed in the wrong orientation. The small lip should be facing FWD so that oil pressure push it against the crank. Also there is marks on the seal in a specific direction to push the oil back... My problem is i cannot find my book anymore... could someone confirm that to me? Thanks,
Re: SB Mopar Rear Main oil leak [Re: tpabayflyer] #133372
08/01/10 07:28 PM
08/01/10 07:28 PM
TBF
Felpro sells the large round gasket that's for between the 90 deg adapter/block. It's thicker than the one in the MP 3 piece kit and it stopped my leak. Make sure the block perimeter there is scrubbed clean w no gasket remnants left in the groove. To the OP I have the Larry Shepherd book handy but cant find a seal part #
Re: SB Mopar Rear Main oil leak [Re: RapidRobert] #133373
08/01/10 09:08 PM
08/01/10 09:08 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I have always used the Felpro rear main seals and they don't leak a drop if installed correctly. I wipe block and cap surfaces down with brake parts cleaner and clean paper towels until they are oil free. If you don't put a thin film of RTV sealer between block and rear main cap it will leak. And like said above, small film of oil on seal surface so it doesn't burn up. Lip facing toward front of engine so oil pressure pushes seal against crank.
