Re: Trans Cooler
[Re: jeebis44]
#1333506
11/10/12 11:44 PM
11/10/12 11:44 PM
RapidRobert
me personally I dont think it is a big deal either way but others who know more than me have posted their preferences & why, iirc something about heating up cold fluid in the winter. I bypass the rad cooler entirely just because if there's a leak in the lower tank I'll see trans fluid in the coolant or coolant could get into the trans. I'd use the largest cooler that will fit & reportedly a "stacked plate" type cooler is more efficient
Re: Trans Cooler
[Re: scratchnfotraction]
#1333512
11/11/12 06:59 PM
11/11/12 06:59 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
in front of rad gets cool air behind the rad gets hot air. = counter productive.. use the least amoung of rubber hose. make sure its transfluid/heat compatable..
I am truckless..
