Re: 1996 ram a/c tech help
[Re: 4spd69gtx]
#133348
10/07/08 10:23 AM
10/07/08 10:23 AM
Posts: 13,610 md
mopars4ever
md
[Re: WILD BILL]
#133351
10/07/08 12:46 PM
10/07/08 12:46 PM
Posts: 21,487 It's a dry heat
gtx6970
It's a dry heat
If you have 35 psi with the system off I suspect you are still low on charge.
[Re: gtx6970]
#133352
10/08/08 01:46 PM
10/08/08 01:46 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
x2 charge it then get ready to do a leak test
[Re: WILD BILL]
#133353
10/08/08 07:20 PM
10/08/08 07:20 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
With the A/C system not running the pressure on both the low and high side should read the same and roughly about what the ambeint outside temp is. The low side should be reading 35-40 psi only when the compressor is running.
Thats dead on. Ron
