Coil Spring Question #1333415
11/10/12 08:39 PM
11/10/12 08:39 PM
Endicott, NY, USA
crazyjjk Offline OP
crazyjjk  Offline OP
Endicott, NY, USA
If you had two coil springs equal in length same wire diameter. If one spring had 8 coils wider spaced coils and the other had 9 closer spaced coils what would be the differences? Remember spring wire thickness and spring unsprung length the same.
Re: Coil Spring Question [Re: crazyjjk] #1333416
11/10/12 08:45 PM
11/10/12 08:45 PM
california
Mr D21 Offline
Mr D21  Offline
california
maybe the amount of compression force each can take
Re: Coil Spring Question [Re: Mr D21] #1333417
11/10/12 09:03 PM
11/10/12 09:03 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
The 9 coil will be softer with less compression travel.
(I think)
Joe
Re: Coil Spring Question [Re: jlatessa] #1333418
11/11/12 12:56 PM
11/11/12 12:56 PM
Endicott, NY, USA
crazyjjk Offline OP
crazyjjk  Offline OP
Endicott, NY, USA
Thats what I thought but I am not sure. I think it has to do with the angle between individual coils. Also seems like the one with more coils to act more like a slinky. That being it will bend over easier. Just not sure?
