What gasket "O" ringed heads? #1333410
11/10/12 08:34 PM
11/10/12 08:34 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
I have a set of hemi MP aluminum heads that have been "O" ringed, now want to use them on a street engine. What gasket would work best? Would rings need to be copper wire filled? Open to suggestions. Thanks
10.5/11.0-1 compression. Pump Gas
Re: What gasket "O" ringed heads? [Re: maximus] #1333411
11/10/12 08:40 PM
11/10/12 08:40 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
what compression?
Re: What gasket "O" ringed heads? [Re: maximus] #1333412
11/11/12 01:39 AM
11/11/12 01:39 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Are there receiver grooves in the block? If yes, then I would go with copper head gaskets. Seal coolant holes on both sides of gaskets with YamaBond.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: What gasket "O" ringed heads? [Re: DusterDave] #1333413
11/11/12 07:12 AM
11/11/12 07:12 AM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
No receiver grooves in block. Just wondering if it would be a bolt on a go.
Re: What gasket "O" ringed heads? [Re: maximus] #1333414
11/11/12 09:46 AM
11/11/12 09:46 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
If there's wire in the groove remove it, slap on a set of cometics and go cat go.
