Dropping the oil pan on a 440 B body #1333166
11/10/12 12:22 PM
11/10/12 12:22 PM
NY
70CoronetRT Offline OP
NY
I had a series of mishaps to make up for my previous perfect record in life. Anyways the fuel pump rod is now laying in the oil pan of my car.
To add insult to injury, the magnet from my magnetic pickup tool is also somewhere in the bottom end.
I know that in my youf, I've done this job about 3 times (dropping the oil pan while still in the car), but I really don't want to do it and I'm ascared about if it can be successfully done with out the rear main seal and the timing chain cover leaking forever.
So, what is the procedure to do this? , without a lift
Also anybody in Metro NY want to do this job for me?
1970 Coronet RT
440 with a six pack won in a crap game.
pw,pb,ps,rear defogger,ac,at, man. adj. seat
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333167
11/10/12 12:35 PM
11/10/12 12:35 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
How about pulling the timing chain cover off and retrieving it that way ?
What I want to know is how you dropped the fuel pump push rod in the oil pan ...
The rear main won't leak , you don't remove it pulling the pan . drop the centerlink out of the way , maybe jack up the motor some ... unbolting the mounts , you just need to have the room to tip and lower it back to clear the pickup tube.
Re: Dropping the oil pan on a 440 B body [Re: JohnRR] #1333168
11/10/12 01:24 PM
11/10/12 01:24 PM
NY
NY
thanks for the reply,
Forgive my ignorance, this may sound like a stupid question, I really don't remember, but maybe it's not in the oil pan? are you saying it's (the rod) in the timing chain area?
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333169
11/10/12 01:36 PM
11/10/12 01:36 PM
ohio
B5 GTX Offline
B5 GTX  Offline
ohio
I removed mine with a 402 pan. It had tiny pin hole that seeped oil. I think If I remember correctly I didn't have to ack it up.
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333170
11/10/12 02:07 PM
11/10/12 02:07 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I usually drop the drag link down and no problems then!
Re: Dropping the oil pan on a 440 B body [Re: Dodgem] #1333171
11/10/12 02:27 PM
11/10/12 02:27 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Drop the center link and it will come down no problem.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Dropping the oil pan on a 440 B body [Re: JohnRR] #1333172
11/10/12 02:34 PM
11/10/12 02:34 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Down to just a blue car now.
Re: Dropping the oil pan on a 440 B body [Re: 68HemiB] #1333173
11/10/12 02:49 PM
11/10/12 02:49 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
The only way that pushrod got into the pan is if someone inserted it into the fuel pump hole and not in its correct place by removing the plug!!!!
Re: Dropping the oil pan on a 440 B body [Re: R/T1968R/T] #1333174
11/11/12 10:31 AM
11/11/12 10:31 AM
NY
NY
I removed the plug, shoved the rod in there and I heard Kerplunck!
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333175
11/11/12 02:30 PM
11/11/12 02:30 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
no, he's saying that it may have just fallen down into the pan, not rolled anywhere and MAYBE can be reached through the opening. it's worth a shot!
Re: Dropping the oil pan on a 440 B body [Re: mikemee1331] #1333176
11/11/12 02:37 PM
11/11/12 02:37 PM
Kirkland, Washington
Pacnorthcuda Offline
IMO dropping the oil pan is less work than the timing cover.
Why not get another magnet and fish around through the drain plug hole first? Might get lucky.
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333177
11/11/12 02:39 PM
11/11/12 02:39 PM
Are you sure that Kerplunk wasn't just the rod sliding down in its bore when you let go? They will do that! You can use grease to make them stay while you put the pump on.
Re: Dropping the oil pan on a 440 B body [Re: mikemee1331] #1333178
11/11/12 03:37 PM
11/11/12 03:37 PM
NY
NY
I already tried fishing around with a magnet. Besides the magnet from the last pickup tool is somewhere in there.
What's the best way to drop the pan?
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333179
11/11/12 04:05 PM
11/11/12 04:05 PM
Remove the center link from the pitman and the idler--DON'T remove it from the tie-rods--this will allow it to drop about 6 inches and the pan will clear. If you're lucky you can access all 20? pan bolts (the forward ones can be tough depending on pan style and how tight it is at the K frame.
Pretty easy stuff.
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333180
11/11/12 08:11 PM
11/11/12 08:11 PM
JohnRR Offline
JohnRR  Offline
No , but with the timing cover off you could retrieve it that way , does the motor have a windage tray ? It might be on that ?
Re: Dropping the oil pan on a 440 B body [Re: Pacnorthcuda] #1333181
11/13/12 09:11 PM
11/13/12 09:11 PM
NY
NY
Without jacking the motor up?
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333182
11/14/12 01:00 PM
11/14/12 01:00 PM
Minn
SportF Offline
SportF  Offline
Minn
You don't have to jack up the motor. Good luck!
Re: Dropping the oil pan on a 440 B body [Re: SportF] #1333183
11/14/12 01:08 PM
11/14/12 01:08 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
As already been stated several times, drop the center link at pitman arm and idler arm. The pan will come right out with no problem.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Dropping the oil pan on a 440 B body [Re: 68LAR] #1333184
11/14/12 11:14 PM
11/14/12 11:14 PM
NY
NY
Hey , I appreciate the replies, but what is wrong with a little clarity for my piece of mind? After all, i'm the one laying on the cold ground to do this.
"Those who can't do anything teach. Those who can't teach become art critics"
Re: Dropping the oil pan on a 440 B body [Re: 70CoronetRT] #1333185
11/14/12 11:52 PM
11/14/12 11:52 PM
JohnRR Offline
JohnRR  Offline
i went and dug out a partially assembled engine, there isn't a lot of room for it to go far with the timing chain installed and the cover in the way. looks like you had to have it in just the right , actually wrong , postion to have it drop , good luck
