Sound/Heat insulation pads 70 challenger #1332990
11/10/12 08:44 AM
11/10/12 08:44 AM
East Concord,NY
BURNTOJO Offline OP
BURNTOJO  Offline OP
East Concord,NY
Does anybody have a recommendation for some sound or heat insulating pads? And does anybody know if someone makes a complete kit for a 70 challenger? Someone said HUSH MAT was good. Thanks!
70 340 challenger FK5
Re: Sound/Heat insulation pads 70 challenger [Re: BURNTOJO] #1332991
11/10/12 10:26 AM
11/10/12 10:26 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Are you talking about like what the factory put in or going a step further and adding extra stuff? Repos of the factory stuff can be had from different people.I went the extra step also. Go to a mobil home supply and get a row of roof flashing. Its self adhesive rubber and aluminum almost like daynamat but at a fraction of the cost.
Re: Sound/Heat insulation pads 70 challenger [Re: 71birdJ68] #1332992
11/10/12 02:42 PM
11/10/12 02:42 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Dynamat although nice is very pricy. Summit for one sells a similar product for a lot less. Only bad thing about these times of sound deadner are they are hard to remove. So you better make sure the floor and such under are painted and sealed up well. My challenger, I used spray on bedline... but mostlyly because of how much welding and patching I did.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Sound/Heat insulation pads 70 challenger [Re: BURNTOJO] #1332993
11/10/12 03:38 PM
11/10/12 03:38 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Re: Sound/Heat insulation pads 70 challenger [Re: BURNTOJO] #1332994
11/10/12 05:24 PM
11/10/12 05:24 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I used dynamat it's nice stuff. If you buy from summit or Jegs go to Amazon first and find the best price. They will match it. I saved a pile of money doing this. I had them price match because I knew Summit would have it in stock and ship quickly. I wasn't sure about the amazon sellers but they were much much cheaper and Summit matched it.
Re: Sound/Heat insulation pads 70 challenger [Re: 71birdJ68] #1332995
11/11/12 04:33 PM
11/11/12 04:33 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Now that's stickin' it to the man. Awesome suggestion!!!!! Thanks!!!
Probably where the other places are getting their stuff from and just stamping their name on it.
Mo' Farts
Moderated by "tbagger".
Re: Sound/Heat insulation pads 70 challenger [Re: BURNTOJO] #1332996
11/11/12 10:41 PM
11/11/12 10:41 PM
East Concord,NY
BURNTOJO Offline OP
BURNTOJO  Offline OP
East Concord,NY
Thanks for all the suggestions!!!! I want to go a little further than factory- so these tips are great!!! Thanks again!!!
Re: Sound/Heat insulation pads 70 challenger [Re: BURNTOJO] #1332997
11/11/12 10:44 PM
11/11/12 10:44 PM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
Stripmasters used a combination of Dynamat and factory firewall/kickpanel insulation on my Challenger.
Re: Sound/Heat insulation pads 70 challenger [Re: 70BigBlockSE] #1332998
11/11/12 11:14 PM
11/11/12 11:14 PM
East Concord,NY
BURNTOJO Offline OP
BURNTOJO  Offline OP
East Concord,NY
Can you use the same stuff on roof before I put regular insulation and headliner in?
Re: Sound/Heat insulation pads 70 challenger [Re: BURNTOJO] #1332999
11/11/12 11:36 PM
11/11/12 11:36 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I got this info from previous posts here on moparts - www.raamaudio.com - was just getting ready to place an order - he's spoken well about on some other sites also
Re: Sound/Heat insulation pads 70 challenger [Re: shakerjoe] #1333000
11/12/12 07:24 AM
11/12/12 07:24 AM
Jacksonville Fl
Jacksonville Fl
heres the roof
Re: Sound/Heat insulation pads 70 challenger [Re: 71birdJ68] #1333001
11/12/12 08:01 AM
11/12/12 08:01 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've heard the Home Depot stuff will stink when it gets hot over 80 degrees.
Do you have experience with that stuff in a car on a really hot day?
Re: Sound/Heat insulation pads 70 challenger [Re: autoxcuda] #1333002
11/13/12 02:54 PM
11/13/12 02:54 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
The stuff I used from home depot was like a closed cell foam. Foil on one side and adhesive on the other. No smell at all. I was too cheap to put dynomat or a look alike in. I think I bought two rolls at about $30 a piece for just the floor of my Challenger.
Re: Sound/Heat insulation pads 70 challenger [Re: BURNTOJO] #1333003
11/13/12 09:06 PM
11/13/12 09:06 PM
East Concord,NY
BURNTOJO Offline OP
BURNTOJO  Offline OP
East Concord,NY
Awesome! Thanks!!!!
Re: Sound/Heat insulation pads 70 challenger [Re: BURNTOJO] #1333004
11/14/12 01:30 AM
11/14/12 01:30 AM
Detroit, Mi
michiganhotrod1 Offline
Detroit, Mi
I went the cheap way on my 70 Challenger, though I was focused on noise (Michigan doesn't have a BIG problem with hot weather).
I went to my closest "Pick and Pull" junkyard and got the under-carpet insulation out of a late 80's "AS" model Chrysler T&C minivan. $20 for the whole floor area, enough material to do two cars. Nice thick insulation with a sound deadening mastic bonded to it. The later 90's insulation is not as good, I suspect more of the task was accomplished by pieces bonded integrally to the floor.
Besides putting it on the floors, and trunk partition, I used 3M upholstery adhesive to glue it to the back of those nasty hard plastic door panels. You need to trial fit it before you glue, as some areas near the armrest are critical to door panel fit and attachment locations.
Seems to have civilized my car some.
Mark
