LA 360 motor mount question. #1332930
11/09/12 10:12 PM
11/09/12 10:12 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
I have a 1978 360 motor. What mounts do I need to mount it in my 74 Cuda? The Cuda came with a 318. Also, where is a good source to buy new ones?
Re: LA 360 motor mount question. [Re: cudabitten] #1332931
11/09/12 10:16 PM
11/09/12 10:16 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
i believe that 74 cars came with spool type engine mounts so the 360 mounts should work fine .
Re: LA 360 motor mount question. [Re: mopar_man] #1332932
11/09/12 10:39 PM
11/09/12 10:39 PM
scratchnfotraction Offline
[/quote
unless it has truck motor mounts.
the last spool type mounts I got was from napa.
a 318 mount will fit if you use some washers to take up the space on the mount and engine lugs.
