Re: Any good video audio on a 440 with .590 cam?
[Re: shoebox]
#1332793
11/09/12 04:26 PM
11/09/12 04:26 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
On Youtube search: dyno motor outside.mov looney dyno day Both are vids of my 915 iron head, flat top piston 440 w/ the Mopar 590 cam being dynoed at Dave Bruns shop.. (Mid America Racing Engines- Washington Iowa)
Curator at Adams County Speed Shop
[Re: CudaPete]
#1332798
11/09/12 05:13 PM
11/09/12 05:13 PM
340man4ever
Creston, Iowa
74Duster383- 11.25 Compression, Heads flow 268/207 850 Carb M1 Intake Motor dynoed [Email]560hp@6200[/Email], 520 Ft/lbs@5100
[Re: shoebox]
#1332800
11/09/12 06:06 PM
11/09/12 06:06 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I found this clip of a nostalgia event last year, i was suprised to see my junk at 1.30 in, 1st run off the trailer, ran 10.23. Mick http://vimeo.com/52627119
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: clovis]
#1332803
11/10/12 03:37 PM
11/10/12 03:37 PM
deaks
robin hood country
What did it run there and did you go quicker with the monos ? Mick
[Re: shoebox]
#1332805
11/10/12 08:05 PM
11/10/12 08:05 PM
deaks
robin hood country
It was at a track just outside of stratford on avon, the birth place of william shakespeare. The strip is named after him. Mick
[Re: Sport440]
#1332807
11/10/12 10:02 PM
11/10/12 10:02 PM
Posts: 553 Kentucky
clovis
Kentucky
It went 9.92/134 there. The monos like many others have said , make the car 60 ft a little better but a lot more consistent.
I just got back from the track and it went 1.409/1.411/1.390/1.384 Those ended with a 9.926/9.925/9.865/9.860 MPH 133.55/134.04/134.59/135.00
The last pass was a new best 9.86/135 and 6.25/110 in the 1/8th.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: Sport440]
#1332808
11/11/12 11:22 PM
11/11/12 11:22 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
GS, Nice running Charger and vids. Whats the rest of your combo. Do you know where your cam is centerlined at.
CL is 107 or 108 if I remember correctly. I was struggling to find the correct offset key to get it closer to 106... back in 1993 when I put the engine together.
Combo is a 30-over stock stroke 440. Unported open chamber EB Performers, M1-4500 intake, 9377 I picked up on Ebay cheap, TRW pistons, stock rods, and a 150 hp Cheater Plate.
