68 Dart Roof Rail Window seal #1332789
11/09/12 02:42 PM
11/09/12 02:42 PM
Harrison Township, Michigan
Hemi SS Offline OP
Hemi SS  Offline OP
I am taking my 68 Dart apart to send out for media blasting. How does the upper window seal molding that follows the roof line come off? This is a 2dr hardtop.
Thanks,Sam
Re: 68 Dart Roof Rail Window seal [Re: Hemi SS] #1332790
11/09/12 05:05 PM
11/09/12 05:05 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You remove the rubber weatherstipping, it is just held in by pressure, then all the screws that hold the stainless channel on. It is glued on and has a thin layer of foam, you have to pry it off the roof rail. The first time you do it it feels like it won't come off, but make sure you have ALL the screws out and pry it hard!
JB Rhinehart, Realist
A-Body's RULE!
Re: 68 Dart Roof Rail Window seal [Re: Rhinodart] #1332791
11/09/12 05:25 PM
11/09/12 05:25 PM
Hemi SS Offline OP
Hemi SS  Offline OP
Thanks for the reply..... I knew there had to be some screws but wasn't sure.
