Re: MSD pro billet distributors and caps GRRRR [Re: jamesc] #1332763
11/10/12 11:33 AM
11/10/12 11:33 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Firecore50 makes a better cap and rotor for an MSD distributor just drop Rick a PM and he will get one out to you
Gus
64 Plymouth Savoy
Dana 60
Re: MSD pro billet distributors and caps GRRRR [Re: fourgearsavoy] #1332764
11/10/12 11:49 AM
11/10/12 11:49 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Firecore Distributors are the only hot forged T-6061 billet aluminum on the market. Zero degrees retard to 10,000 rpm. Nobody can say that.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: MSD pro billet distributors and caps GRRRR [Re: sunroofgtx] #1332765
11/10/12 11:56 AM
11/10/12 11:56 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive been using MSD probillit for the last 10 years with minimal rusting and no cap wear,only about 2,000 mi a year.and my car sits outside in sw fla,
Re: MSD pro billet distributors and caps GRRRR [Re: bonefish] #1332766
11/10/12 01:36 PM
11/10/12 01:36 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
That's an easy fix. When you put the new cap on give it a spray with WD-40. Problem solved. Been doing it for years and the caps always look new when I pull them.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: MSD pro billet distributors and caps GRRRR [Re: sunroofgtx] #1332767
11/10/12 03:38 PM
11/10/12 03:38 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
These aren't even available right now, or are they?
Will they offer a distributor with both fully adjustable mechanical(rate and amount of mechanical advance) AND fully adjustable vacuum advance (rate and amount of vacuum advance) for an RB motor?
Re: MSD pro billet distributors and caps GRRRR [Re: jbc426] #1332768
11/10/12 08:50 PM
11/10/12 08:50 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Yes, they have undergone some updates, but now are the perfect unit. Yes on the vacuum advance, but next year. We have the mechanical advance that plugs directly to the MSD box, and a ReadyTORun that has it's own internal ignition module. Big write up in Mopar Muscle in the Dec issue against the MSD 6AL> Good read. It is all that Muscle Motors, FHO, and Bob George uses.
Re: MSD pro billet distributors and caps GRRRR [Re: sunroofgtx] #1332769
11/11/12 01:47 AM
11/11/12 01:47 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I replaced a cap last weekend due to the carbon being gone, it was actually concave and you could see where the spark has been arcing to the rotor because they didn't touch anymore. So I swapped to a new msd cap and no cage In performance at all.
68 Barracuda Formula S 340
Re: MSD pro billet distributors and caps GRRRR [Re: Bad340fish] #1332770
11/11/12 03:41 AM
11/11/12 03:41 AM
Washington
skrews Offline
skrews  Offline
Washington
Same problems with my MSD distributor, rusty inards and carbon center electrode burning down to nothing. I drill .030 vent holes between every terminal. This seems to have cleared up the rusting issue. I also replaced the oil filled canister coil for a Blaster SS E-core coil on the advise of the local speed shop which seems to have significantly reduced the carbon electrode terminal deal.
Re: MSD pro billet distributors and caps GRRRR [Re: skrews] #1332771
11/11/12 04:38 AM
11/11/12 04:38 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'm looking forward to trying one of the upcoming vacuum advance units.
My Pro-billet unit was really corroding pretty bad. I cleaned and coated the reluctor with that rust converting coating, but it was still corroding badly.
I realized my rotor phasing was way off, and corrected that using an MSD adjustable rotor. The corrosion problem problem virtually went away.
My latest issue is that the cap terminals and rotor tip are getting a black coating build-up on them after a few hundred miles. The center electrode looks normal. The build-up causes a roughness at idle and low RPM. Once I scrape it off, it runs smooth again. Has anyone else experienced this build-up?
Re: MSD pro billet distributors and caps GRRRR [Re: sunroofgtx] #1332772
11/11/12 06:00 AM
11/11/12 06:00 AM
sweden
sshemi Offline
sshemi  Offline
sweden
And what about small blocks?
