Removal of stick on type hood scoop from aluminum hood. #133259
10/06/08 10:38 PM
10/06/08 10:38 PM
Midland, Tx
rjones Offline OP
rjones  Offline OP
Midland, Tx
The one I have is on a 68 dart and is similar to what was on the the 68 hemi darts and barracudas. It is just stuck on (I am suprised at how well it adhered to the hood) with a strip of double sided tape to a hood I made of aluminum. Since the hood is made of aluminum I can't get super rough with it. I would appreciate any suggestions on a gentle method of making the tape release fairly easy without damaging the hood. The hood is not painted so I think the use of a release agent would be ok.
Roger
Re: Removal of stick on type hood scoop from aluminum hood. [Re: rjones] #133260
10/06/08 10:44 PM
10/06/08 10:44 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You try cutting through the tape with fishing line or floss ?
Re: Removal of stick on type hood scoop from aluminum hood. [Re: rjones] #133261
10/07/08 05:06 AM
10/07/08 05:06 AM
places
79powerwagon Offline
places
You can use a solvent like lacquer thinner, and use little shims as you work it off (to keep it from sticking back down).
Re: Removal of stick on type hood scoop from aluminum hood. [Re: 79powerwagon] #133262
10/07/08 06:57 AM
10/07/08 06:57 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Use a heat gun, heat a bit at a time and it should come of without causing any damage. I have removed those cheap tape on scoops before without hurting the paint underneath this way.
