Re: Need W2 header flanges where and whos?
[Re: DaKuda]
#1332522
11/09/12 10:54 AM
11/09/12 10:54 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Who sells a good quality W2 header flange? Can a 2" tube be fitted to it when building headers? Also, if I later switch to Indy 360-1's will the headers work with both?
Hedman make a set of two inch if thats what your after. They also sell the peices to build your own if you have a strange chassis. The indy heads have both w2 bolt patterns on them so as long as you use a w2 bolt pattern they will fit. The hedman use a adpator plate to get the room for the center exhaust ports.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: DaKuda]
#1332524
11/09/12 12:45 PM
11/09/12 12:45 PM
Posts: 2,826 NY usa
540challenger
NY usa
Thanks guys. I noticed that TTI sells the flanges but they show 1 set for the econo head and 1 set for the race head. Is there a difference and does it matter.
yes the center 2 bolt hols are in different locations, some heads are drill for both patterns, so it might not be a factor.
[Re: 540challenger]
#1332525
11/09/12 10:05 PM
11/09/12 10:05 PM
1967dartgt
Hilltown Pa
I wpould use the race pattern, as that is a wider pattern on the center holes. But you need to see what your w2 heads are. Econo or race pattern, as the indy's come with both.
[Re: DaKuda]
#1332527
11/11/12 02:20 AM
11/11/12 02:20 AM
1967dartgt
Hilltown Pa
Yes I switched from batten w2s to the indy 360-1 245s with no problems. I had a set of tti 1 7/8 headers and hedman 1 7/8 headers on the car.
