Post your 10-11second 383 combos
#1332319
11/08/12 02:00 PM
11/08/12 02:00 PM
Posts: 48 PA
Belvedere500ci
PA
Looking to overhaul my 383. 516 heads, solid cam, stock stroke and rods. Goes 12.0s in my 67 Belvedere. Would like to get some more out of it without spending a ton. I have a set of 440 source heads I'm considering throwing on. Would love to see high 10s, would be happy with 11.20s. Any input??
1967 Plymouth Belvedere II 383 1968 Plymouth Barracuda 383 2005 Ram 3500 5.9Diesel 1979 Dodge Power Wagon 360
Re: Post your 10-11second 383 combos
[Re: Belvedere500ci]
#1332321
11/08/12 04:46 PM
11/08/12 04:46 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
When I had the 383 w/440 crank (431), RPM heads massaged by Dwayne, Schubeck lifters, (.550 lift as I recall), RPM manifold, 800 Holley, Jerico, 4:10 gears, my best was 11.09 (Atco) @124. Still had trouble hooking. If only I had hooked.......
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: Triple Threat]
#1332322
11/08/12 11:41 PM
11/08/12 11:41 PM
Posts: 48 PA
Belvedere500ci
PA
Not interested in stroking. I built a 500 I had to take out from to much torque not enough traction. Just looking to get the most out of what I got and save my $$ for my 4link Barracuda. Cam? Heads? Intake? Pistons? Comp ratio?
#1332323
11/09/12 12:02 AM
11/09/12 12:02 AM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
.030 over 383, TRW L2315's, block milled for .020" positive deck height, stock rods w-ARP bolts. stock 906's flowed 235, Comp solid cam, 256/262-106, .565/.580 lift, 1.5 Isky rockers, RPM intake, ported 850 Holley, Hooker Comp headers. dynoed at 485hp.
went 11.30's/40's in "normal" air, with a flat hood, mechanical fuel pump, full interior, heater, wipers, etc......3670lbs race weight. on hot summer days, 11.50's.
6 pak hood, electric fuel pump, 100lbs lighter.....went 11.18 @ 123, 1.51 60 foot.
the key is getting the car to work. lots of gear, lots of stall, good hook.
i ran 30 X 9 radial slicks, 4.56 gears, 5400 stall 8" Dynamic converter.
[Re: 440charger500]
#1332325
11/10/12 10:23 AM
11/10/12 10:23 AM
Posts: 48 PA
Belvedere500ci
PA
My chassis has a full cage and 2x3 frame connectors. Caltracs complete setup split mono leafs, bars, rancho shocks, lowered 1 inch. 90/10s up front with 6 cyl torsion bars. Only thing I dont have are the "fancy" bushings for the upper control arms. I found somebody that makes them but I think I'm just going to get the tubular arms with the heim ends. 456 braced 8 3/4 with a spool and a ATI 8 in converter. Id love to use the 500 again but I just moved to ny and all the tracks up here don't believe in Vht I guess. Lol. So I'm looking to beef up this 383 to leave soft and go like hell on the other end
#1332326
11/11/12 03:05 PM
11/11/12 03:05 PM
Posts: 854 Bloomingdale , OH
super451b
Bloomingdale , OH
383 stock stroke and rods. MP 590 solid cam , Probe domed pistons,452 heads 2.19 x 1.81 with my home porting cut .080, TM-6 with 1" open + 1" spacers , 926cfm 4150, hooker super comps, 727 w/ 8" 5200 stall, 4.56 13 x 31 , 3500 lbs. , bests are in my sig.
[Re: super451b]
#1332327
11/11/12 09:55 PM
11/11/12 09:55 PM
Posts: 48 PA
Belvedere500ci
PA
Nice, thanks. I am def going to change cams. I really think I'm going to go with the MP 590 cam or do you think I should have more lift?
