Re: Mopar electronic ignition double fires at idle
[Re: Clair_Davis]
#13319
09/21/04 10:10 AM
09/21/04 10:10 AM
Posts: 556 Arkansas
GregGarner
Arkansas
I am using a Tektronix TDS3054B. It is a 500Mhz 5Gs/Sec 4 channel scope. I don't have the one with the nifty web server in it, unfortunately, so I have to take pictures of the screen with my camera. Here is a picture showing two cylinders firing. The yellow trace is connected to the minus side of the coil. The blue and purple traces are connected to the pickup coil in the distributor. In this picture you can clearly see the extra thin pulse right after the main pulse. You can also see (in the blue line) that the pickup coil commanded the Orange ECU to fire twice. Here is the original picture in full 5MPixel resolution: http://rt-eng.com/mopar/tachboard/2004-09-21_014.jpg GregGarner www.rt-eng.comgreg@rt-eng.com
GregGarner www.rt-eng.com Home of the mopar solid state limiter adn tach repair kit
[Re: GregGarner]
#13320
09/21/04 10:13 AM
09/21/04 10:13 AM
Posts: 556 Arkansas
GregGarner
Arkansas
I also looked at the three distributors I had handy, and all three had reluctors that are held on with a roll pin. GregGarner www.rt-eng.comgreg@rt-eng.com
[Re: john55]
#13322
09/21/04 11:38 AM
09/21/04 11:38 AM
Posts: 556 Arkansas
GregGarner
Arkansas
The TDS3054 won't save an image, but it will save a CVS (Commad Delimited) text file. That is how I created the first graph (at the top of this thread) in excel. GregGarner www.rt-eng.comgreg@rt-eng.com
[Re: GregGarner]
#13323
09/22/04 12:20 AM
09/22/04 12:20 AM
Posts: 556 Arkansas
GregGarner
Arkansas
Ok, here is the latest. I completely rebuilt my distributor. It now has no play in it at all. Unfortunately, the system is still double firing. I then noticed that the shaft that drives the distributor was very worn on top and allowed some play in the distributor, so I yanked that out and put in a new one. Again, this made no difference, the system still double fires at idle. I then got a silver ECU from a friends car, and put it on the car. No difference, it still double fires. I checked the silver ECU on the other car, and it does not double fire. I am using all different parts inside the distributor, except for the pickup coil. I even changed the reluctor and tried a different reluctor. I only had one good pickup coil around, so I plan on buying a rebuilt distributor tomorrow and trying that. I may also purchase a new MP distributor and try one of these as well. Anyone else have any other ideas to try? GregGarner www.rt-eng.comgreg@rt-eng.comIt's got to be either the pickup coil or something in the engine or wiring at this point, as we have eliminated everything else it could be.
[Re: GregGarner]
#13325
09/22/04 07:53 AM
09/22/04 07:53 AM
Posts: 3,842 Ohio
john55
Ohio
GregGarner www.rt-eng.com greg@rt-eng.com
Greg,
Is the secondary ignition ok, plug wires routed correctly and away from the pick up wires?
The Plymouth Win You Over Beat Goes On
[Re: john55]
#13326
09/22/04 08:29 AM
09/22/04 08:29 AM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I would turn the distributor in a lathe or drill press to eliminate a noise issue. I have done that in the past to test distributors. Turn the shaft out of the car and look at the waveforms.
I was just checking my MSD this week with my scope. Neat how it was firing 3 pulses at idle, then 2 and then one. I thought that the 7AL2 puts about 450 volts to the coil, but when I zeroed in on the pulse it was off scale with a X10 probe. Couldn't find a X100 probe, although didn't look too hard.
[Re: WINGCARS_6970]
#13327
09/22/04 08:52 AM
09/22/04 08:52 AM
I think Don at 4 Sec Flat had some tests on the "orange box", that were not very flattering.. AIR, he found SERIOUS loss of plug voltage at higer rpms. Maybe a good distributor and a good box, [I think he has one that shows significantly better performance] would really "step up to the plate" w/ some improved performance???
#13328
09/22/04 09:26 AM
09/22/04 09:26 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
I was going to mention Don/FBO also. IIRC, he found the orange box to have a significant ignition retard "feature" at higher (4500+??) rpm. I don't know if I ever heard WHY this was happening, just that it was. I'll be looking seriously at one of his systems for my Barracuda when I get to that point.
Clair
[Re: GregGarner]
#13330
09/22/04 12:49 PM
09/22/04 12:49 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
have you bought a new pickup for it yet?
[Re: patrick]
#13331
09/22/04 01:55 PM
09/22/04 01:55 PM
Posts: 7,595 TX , NJ , FL
WINGCARS_6970
TX , NJ , FL
Can a mopar ECU misfire due to Voltage spikes or a faulty alternator emmiting a frequency.I heard that GM modules would go bad early as constant miss firing would wear them out.Are the mopar ones effected by these conditions
1969 Daytona 440 L9B410772
1970 Coronet 500 383 Presently owned
1970 Superbird 440 U 166242
1970 Superbird 440 U 174597
1970 Superbird 440-6 V 179697
1970 Coronet RT 440 U 224126
1968 Road Runner 426 J 134509
1970 Daytona Replica 318 G 178701
[Re: WINGCARS_6970]
#13332
09/23/04 01:27 AM
09/23/04 01:27 AM
Posts: 556 Arkansas
GregGarner
Arkansas
You guys are not going to believe what the problem turned out to be. Thanks for all the excellent suggestions, as they helped me track this problem down.
First of all, I got a replacement distributor from O-reilly, very nice looking, for $54 including tax. I popped that puppy in, expecting my problem to go away, and it still double fired.
So I thought, well, it must be either the engine or the wiring. I then hooked up the distributor to a drill and looked at the waveforms as suggested. It was a very nice waveform with no double pulses.
I made a nice little test harness out of two of those 4 pin trailer wiring harness jacks, so that I could plug in between the distributor and the wiring harness and look at the signals with the scope. I then looked at the distributor pickup signal, and this time there was no double firing. So I added the scope probe back to the minus side of the coil, and sure enough, no double firing. Somehow adding the test harness fixed the problem!
Possibilities that went through my head: Inductive pickup where my wires were picking up spark, extra capacitance of the scope probe, extra inductance of the 1 ft test harness. I move the harness around, thinking that if it were inductive pickup, then it should be easy to make it happen. Moving the wires did not make it double fire. Finally it hit me: I had wired the test harness such that it swapped the two pickup wires, changing the polarity of the pickup signal. What luck!
I then yanked out the handy dandy Moparts electronic distributor wiring, and looked closer at my harness. The harness I have has a brown wire and a black wire going from the 2 prong plug to the Orange ECU unit. The harness is wired exactly backwards from what the moparts diagram says it should be! The brown and black wires are not swapped, so I think it was wired this way from wherever the harness came from, which is no telling where.
I yanked the harness out of the car and peeled back the tape next to the two prong plug and swapped the wires, heatshrinking and soldering the connections. I then put the harness back in the car, and no double fire!
I then hooked up one of my tachs with a reproduction board in it, and the tach worked perfectly, reading the proper RPM everywhere.
Whew, what a relief!
Here is the URL of the wiring harness so you can check your harness and see if it is backwards. This diagram is definately correct, it shows the correct polarity.
http://www.moparts.com/Tech/Archive/elec/3.html
Here is my Half Baked Theory on what is going on:
The Orange box is probably supposed to fire on the rising edge as the reluctor approaches the pickup coil. Since I had my polarity backwards on the pickup coil, it was firing as the reluctor left the pickup coil. As the ignition coil fired, it generated a 260V positive spike on the minus pickup of the coil. This spike is inductively coupled to the two pickup wires, and since the reluctor is not near the pickup coil anymore to create a voltage source, it causes the Orange box to fire again. This may not be exactly what is going on, but it is something like this.
Does Don/FBO have a link on the web to the aftermarket ECU units you guys were mentioning above?
GregGarner
www.rt-eng.com
Greg@rt-eng.com
[Re: GregGarner]
#13333
09/23/04 08:22 AM
09/23/04 08:22 AM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
I tried this on my car this AM and it made it run rough and actually made the tach read even higher!! What's up?
11B40
[Re: markz528]
#13335
09/23/04 11:13 AM
09/23/04 11:13 AM
Posts: 556 Arkansas
GregGarner
Arkansas
Jon:
Make sure you retime the car after you swap the wiring. It changes the timing pretty drastically because now it will be firing when the reluctor approaches the pickup coil instead of firing when the reluctor leaves the pickup coil. This could explain why it seemed to run rougher.
As far as it reading higher, I can't explain that. Was your ECU wired backwards according to the wiring diagram? Do you have access to a scope so you view the signal on the minus side of the coil?
GregGarner
www.rt-eng.com
greg@rt-eng.com
[Re: GregGarner]
#13336
09/23/04 12:46 PM
09/23/04 12:46 PM
JonC
Millinocket, Maine
I'll check it after work tonight, don't have time right now. I have a buddy that has a scope.
11B40
[Re: JonC]
#13337
09/23/04 01:33 PM
09/23/04 01:33 PM
WINGCARS_6970
TX , NJ , FL
So your saying its the black molded plug going to the pick up.With the female and male terminals.Was the problem on the repo harness .Or the mopar replacment one.
