Reference Book for building a Street Rod #1332102
11/07/12 09:44 PM
11/07/12 09:44 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I posted this in general and forgot about this section. I want to build one, is there any good books out there to use as a reference for ideas and suggestions?
Re: Reference Book for building a Street Rod [Re: 1fastrunner] #1332103
11/07/12 10:20 PM
11/07/12 10:20 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
http://s858.photobucket.com/albums/ab141/moparpollack/
All the brake plumbing is done, had to make motor and tranny mounts which wasn't that bad. Doing front bumper mounts now. Then I'm pulling the motor to finish the firewall. Pedal and steering wheel was from a 64 savoy.
Re: Reference Book for building a Street Rod [Re: 1fastrunner] #1332104
11/07/12 10:24 PM
11/07/12 10:24 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I can't recommend any books as a reference but you can get just about any info you might need right here, there are many guys here that have "been there, done that"
first you would need to figure out what you would like to build, such as I won't settle for anything but a 33-34 coupe, that will bring your search very tight and pricey, but if you want anything mopar then that will open the door pretty good. trucks are pretty easy to find for a reasonable price, earlier cars and trucks are usually higher priced to start with. you really need to look at pictures of Rods you might like and then figure out if it would fit in to your budget Ron...
Re: Reference Book for building a Street Rod [Re: Mopar Ron] #1332105
11/07/12 11:34 PM
11/07/12 11:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Tex Smith wrote decent one for Mopars a while back. Frank Oddo's and anything by Boyd Coddington is horrible for MoPar related stuff. Other than that, I have no suggestions.
Don't be the exception.
Re: Reference Book for building a Street Rod [Re: Supercuda] #1332106
11/08/12 12:27 AM
11/08/12 12:27 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I might suggest you check www.carnut.com and begin by looking at some pictures of cars under Plymouth, Dodge and Chrysler (Hudson, Packard and Nash are considered distant relatives of Mopars) from about 1928-1950. Lots of pictures, lots of variety, should entertain you for a couple of hours. At least you will get an idea of a body style, manufacture, and year range that appeals to you. Once you narrow down the choices a bit, we will be more then happy to share more specific information. Gene
Re: Reference Book for building a Street Rod [Re: poorboy] #1332107
11/08/12 12:53 AM
11/08/12 12:53 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Narrow down what you can afford and what you want to build. That will help a LOT.
Example, Model A with a Ford flathead V8, there is a great book by Vern Tardel.
T bucket, there is the build plans from Speedway (Used to be Total Performance).
Mopar, it really depends on the era. The Tex Smith book has some good info but is very outdated and expensive to buy.
Often the budget will determine the starting point and the build style. A Pro-Touring 2 Door Airflow is out of reach for almost all of us. A 40s build with the stock flatty, a T-5 and rear axle swap, along with a disc conversion and shock relocation is probably the lowest cost.
Earlier stuff is more expensive and requires more work. Post 1948 is not considered Street Rod as much.
Narrowing the candidates also helps point to the catalogs and companies that you can use in the build.
I will say that Mopar rods are often priced cheaper than you can build them. Provided you have the funds and the car is built right, you can often get a great deal on a done car. Especially if you are willing to yank out a SBC and install a real motor.
http://cgi.ebay.com/ebaymotors/1936-Plym...=item25773b4a0e
Re: Reference Book for building a Street Rod [Re: 1fastrunner] #1332108
11/08/12 10:00 AM
11/08/12 10:00 AM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
Some guys aren't going to agree with me but unless you have a very big wallet, get it to where you can drive it and then keep working on it while you enjoy it. To many guys want to build the perfect street rod and go year after year working on it when money permits while never using it or finishing it. Eventually it sits and becomes a project you never use or complete.
Re: Reference Book for building a Street Rod [Re: 1fastrunner] #1332109
11/08/12 10:08 AM
11/08/12 10:08 AM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
http://www.jalopyjournal.com/forum/forumdisplay.php?f=5
More street rodders than you can shake a stick at on the H.A.M.B.
You may be able to find some references to books over there. If you sign up over there, be sure to do your introduction or you'll get the boot or the cold shoulder.
Re: Reference Book for building a Street Rod [Re: John Brown] #1332110
11/09/12 03:07 PM
11/09/12 03:07 PM
Mopar Ron Offline
Mopar Ron  Offline
1fastrunner where you at???
we would like to know what type of rod you were looking to get in to?
Re: Reference Book for building a Street Rod [Re: John Brown] #1332111
11/13/12 08:19 PM
11/13/12 08:19 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
And do NOT mention anything like Rat Rod, EFI, Radials, Patina, Billet, Pro Street, etc. Just read some posts and you will see what can and cannot be said or discussed. Other than that, alot of good info can be had.
Re: Reference Book for building a Street Rod [Re: TrWaters] #1332112
11/13/12 10:01 PM
11/13/12 10:01 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
