727 trans using a deep diesel 5 inch deep pan #1332010
11/07/12 05:17 PM
11/07/12 05:17 PM
Canada
bucket Offline OP
bucket  Offline OP
Canada
has any one used a deep trans pan from diesel truck on a car? any problems bottoming out?
Re: 727 trans using a deep diesel 5 inch deep pan [Re: bucket] #1332011
11/07/12 05:33 PM
11/07/12 05:33 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I don't think it is 5 inches, although at least 4 inches. I can take an exact measurement later tonight. This is installed on my 68 Road Runner and after 1500 miles it has not hit anything. I also use a deep Milodon oil pan and they are roughly the same as far as clearance.
Re: 727 trans using a deep diesel 5 inch deep pan [Re: 68jim] #1332012
11/07/12 05:35 PM
11/07/12 05:35 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
#2
Re: 727 trans using a deep diesel 5 inch deep pan [Re: 68jim] #1332013
11/07/12 05:41 PM
11/07/12 05:41 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Side shot showing the oil pan. My RR is set up for stock ride height with 15" rims.
Re: 727 trans using a deep diesel 5 inch deep pan [Re: 68jim] #1332014
11/07/12 08:30 PM
11/07/12 08:30 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I checked with a ruler tonight and it is just under 4" deep. It is the lowest point under the car and currently it has 5.25" ground clearance. The oil pan has 5.5". I'm also running slightly stiffer torsion bars - .96" vice the stock size .92". So far it works for me...your results may vary...
