Re: How fast can I go with a 440 street dominator?
[Re: 383man]
#1331375
11/06/12 03:41 PM
11/06/12 03:41 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I agree w/ everyone else...that's a great manifold. I went 11.40s in a 3700# cuda w/ a mild 440 and the SD intake.
[Re: 70moparmike]
#1331381
11/08/12 03:22 PM
11/08/12 03:22 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
any pic's on a street dominator? will an air grabber hood still fit with this intake? sorry trying not to jack this post
I don't have picture handy but google/images should be able to find you one.
On the fitment issue, I did measure a number of manifolds a while back so see which ones were tall and which were short.
The column labelled "average" is the effective height but also interesting is the angle of the carb. flange. The Street Dominator was 1" taller than the stock manifold I used for reference. If you've subscribed to the emails on this thread you'll need to click the moparts link to see the attached picture with the data. (btw, the Streetmaster is available )
[Re: @#$%&*!]
#1331382
11/08/12 03:59 PM
11/08/12 03:59 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
The column labelled "average" is the effective height but also interesting is the angle of the carb. flange. The Street Dominator was 1-7/8" taller than the stock manifold I used for reference. (btw, the Streetmaster is available )
My Street Dom measures 4.75", verses your 5.75", about 1" taller than stock. I think you have a math error.
[Re: Mick70RR]
#1331386
11/08/12 05:20 PM
11/08/12 05:20 PM
Thigh-Gap Junction
Are you sure your sums are correct? Street Dominator average doesn't look right.
I agree, it doesn't look right. I probably did the math in my head It looks like it should be 1" taller than the Street Master, with the same angle as the SM. That would put it at 4-7/8" I'll do an edit on the data.
