Installing Degree wheel... #1330909
11/04/12 11:34 PM
11/04/12 11:34 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
when setting up to install the degree wheel how are you guys keeping the motor from rotating around while getting it tight enough to rotate it in reverse? Is everyone doing this with the pan off so you can block the crank to the block or is there a better way, I of course already have my pan on & I own a shi**y impact gun so I cant just run it down with that.
Good ideas anyone?
Thanks ,Evan
Re: Installing Degree wheel... [Re: edp] #1330910
11/05/12 12:01 AM
11/05/12 12:01 AM
WA
JD Dart Offline
JD Dart  Offline
WA
Impact gun I just use saftey wire and adjust it so it reads 0 at TDC
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Installing Degree wheel... [Re: JD Dart] #1330911
11/05/12 12:04 AM
11/05/12 12:04 AM
Mid Missouri
1moparcrazy Offline
1moparcrazy  Offline
Mid Missouri
put two bolts in the rear crank flange and hold a bar between the bolts while tightening the front.
Re: Installing Degree wheel... [Re: 1moparcrazy] #1330912
11/05/12 12:09 AM
11/05/12 12:09 AM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
I never try to turn the motor over with the front bolt. Three or four bolts in the rear and use them to turn motor while degree in cam and returning to TDC. frt bolt comes off by hand and now can check balancer.
Re: Installing Degree wheel... [Re: Cuda367] #1330913
11/05/12 12:20 AM
11/05/12 12:20 AM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
cool, I like the 4 in the rear idea, finger tight on the ft bolt seems a much better idea. Whats the size & thread count of the rear bolts, anyone know off the tops of their heads?
Thx!
Re: Installing Degree wheel... [Re: edp] #1330914
11/05/12 12:41 AM
11/05/12 12:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Invest in a degree wheel socket... makes life much
easier.... I use the Comp cam one but this is the
Powerhouse one
http://www.summitracing.com/parts/pow-pow103070
Re: Installing Degree wheel... [Re: Cuda367] #1330915
11/05/12 01:21 AM
11/05/12 01:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So what ... you have another guy stand at the front to watch the degree wheel while you turn it at the back ?!?!?!?
Re: Installing Degree wheel... [Re: Stanton] #1330916
11/05/12 01:45 AM
11/05/12 01:45 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
thats what i was thinkin,or use a mirror.
Re: Installing Degree wheel... [Re: bonefish] #1330917
11/05/12 01:51 AM
11/05/12 01:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure will be a PITA... just get the right tool
Re: Installing Degree wheel... [Re: MR_P_BODY] #1330918
11/05/12 02:23 AM
11/05/12 02:23 AM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
Powerhouse one
Ok thats interesting, didn't know they existed. I can see the keyway slot but not much else, looking at on phone... Hows it turn?
after looking at it on my computer I can see how it works now, the thing that annoys me more than anything is not having to buy the tool just that I cant go anywhere & pick it up. No speed shops anymore or real tool dealers, all online only.
Re: Installing Degree wheel... [Re: edp] #1330919
11/05/12 03:20 AM
11/05/12 03:20 AM
Powerhouse one
Ok thats interesting, didn't know they existed. I can see the keyway sbut not much else, looking at on phone... Hows it turn?
I use the large end of a half inch extension stuck in one of the balancing holes on the front crankshaft counterweight and turn the crankshaft over so the extension rests on the oil pan rail of the block , tighten the bolts and set the TDC pointer as needed. I do get the degree wheel close before tightening, adjust as needed If I have one head setting on the motor I have used a spark plug compression hose and scerw in fitting that I can apply air into the cylinder and then use the air pressure to hold the crank Lots of ways to get the job done
Re: Installing Degree wheel... [Re: edp] #1330920
11/05/12 08:54 AM
11/05/12 08:54 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
I had a crank socket made, actually 2, one for assembly to turn the crank while installing pistons/rods; the other is for degreeing the cam. They are broached to slide over the key on the crank snout, and no worries about the crank bolt backing out.
Re: Installing Degree wheel... [Re: edp] #1330921
11/05/12 09:02 AM
11/05/12 09:02 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The Moroso wheel is too small imo, I don't use it. Got it in a E bay deal, it's a extra.
Re: Installing Degree wheel... [Re: MR_P_BODY] #1330922
11/05/12 09:03 AM
11/05/12 09:03 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
tere is no substitute for the RIGHT tool,store bought or home made
Re: Installing Degree wheel... [Re: edp] #1330923
11/05/12 09:30 PM
11/05/12 09:30 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Hold the crank from the back and tighten the degree wheel down.
