Re: Floor shifter for a 4 speed
[Re: tripleblackcuda]
#1330720
11/04/12 06:25 PM
11/04/12 06:25 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I prefer a Hurst Super Shifter III for an H-pattern unit There are many vendors that can hook you up with a new or re-man shifter but I like dealing with Jamie Passon at Passon Performance. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1330726
11/04/12 11:50 PM
11/04/12 11:50 PM
Posts: 43,595 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
His problem is that he has an automatic trans in a car with a 4-speed floor hump, so he cannot use a stock type floor shifter. You can use any aftermarket cable type shifter, that is the only way to go unless you use a column shifter but you will have to get all the linkage. If you change the column you will have to get one for manual steerring or power steering as the PS column is shorter.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1330727
11/05/12 12:50 AM
11/05/12 12:50 AM
Posts: 998 Sturgis S.D.
tripleblackcuda
Sturgis S.D.
Thats correct, the car has an automatic trans in it. The car has a 4 speed hump, so I need to buy a shifter to work with that hump and the auto trans.
#1330728
11/05/12 09:48 AM
11/05/12 09:48 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I have a new auto shifter I bought probally 40 years ago for my Auto Bee.It uses solid linkage not a cable.It has a flat plate that bolts to the floor.I bought it for the linkage for my Hurst auto shifter that was missing the steel linkage.Biggest problem is that there is no gate to show you what gear you are in.Looks just like a 4 speed when bolted to the floor.You can cut a piece of steel and bolt it to the hump and attach the shifter to it.Rocky
Chrysler Firepower
#1330730
11/05/12 02:34 PM
11/05/12 02:34 PM
therocks
Niles , Ohio
The shifter I have in the garage has a flange on the bottom.Bolts to the floor.Then the end sticks thru the floor and the linkage connects to it.I cant even remember who made it.Sitting on a 4 speed hump it would look just like a stick car.Rocky
Chrysler Firepower
