69 Charger headlights #1330691
11/04/12 03:56 PM
11/04/12 03:56 PM
ontario
70plumrt Offline OP
70plumrt  Offline OP
ontario
When I turn on the lights the doors close and when I shut them off the headlight doors open!
Where do I start?
Thx
1969 Charger 1968 Charger R/T 1972 RR TB3 340/4 spd 2002 Ram 1998 Durango
Re: 69 Charger headlights [Re: 70plumrt] #1330692
11/04/12 04:04 PM
11/04/12 04:04 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The vacuum lines are reversed.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 69 Charger headlights [Re: HemiRick] #1330693
11/04/12 04:05 PM
11/04/12 04:05 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
diaphragm
I bet if you reversed the lines at the front vacuum motors it would be fixed.
Take care,
Rick
Re: 69 Charger headlights [Re: HemiRick] #1330694
11/04/12 09:13 PM
11/04/12 09:13 PM
ontario
70plumrt Offline OP
70plumrt  Offline OP
ontario
Thanks Rick!
That was a huge help!
I switched the two lines and it works better
Before, the pressure was keeping doors down when lights were on...
now doors open or partially open and the one closes and the other closes sometimes.
I'll have to check the hoses for leaks I think.
Thanks again!
