I used a external regulated 120 amp denso on the 440 truck. it was from a 90 van premag 318 with a 2 groove pully.(in the sig pic)
I fliped it over and used the 1 single lug at the pivot bolt and made up a spacer bolt for the 2 lugs for adjustment.
this moved the Batt post out away from the head/block so i would not have to cut the plastic shield or grind the Batt stud down for clearance. crimped on 2 eyeloops for the feild wires and hooked it right up with stock wires.
it used the non a/c BB alt brackets,has the stock VR on the firewall.
if you want the 1 wire internal regulated denso and plan to wire it so. Andys set up is the way to go. and you may not need to grind the Batt stud for clearance.
I looked at my 85 SB non a/c alt brackets and it will fit the same way fliped over. as soon as I score another mini alt I plan to swap it over to the SB truck also.
I hear from steve I just missed you in the hamburger line at Garlits.
2x no steering colum for me
I think I will buy a whole truck and part it out to save some coin on travel expenses.
