413 piston advice #1330587
11/04/12 11:30 AM
11/04/12 11:30 AM
ohio
B5 GTX Offline OP
B5 GTX  Offline OP
ohio
Working on a friends 413, took it apart yesterday and it will need to be bored out. What are the best options for pistons? It seems like there's not many. Not looking for an all out race motor(its for a boat).
thanks
scott
Re: 413 piston advice [Re: B5 GTX] #1330588
11/04/12 12:00 PM
11/04/12 12:00 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
thanks
scott
Maybe this may help you or point you in the right direction Scott. Check out the EGGE Machine Company website. The application for a 413 piston set is L2095-8 and it's possible that oversize pistons are available. Prices look decent. Good luck with your project.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 413 piston advice [Re: HYPER8oSoNic] #1330589
11/05/12 04:29 PM
11/05/12 04:29 PM
USA
max Offline
super gas
max  Offline
super gas
USA
Pistons aren't cheap for a 413 engine.
I bought a set of .060 over pistons at Jegs a few years ago and they carried .030, .040 and .060 over size at that time. Rings are another thing that isn't cheap if you go with the .030 or .040 over pistons.
I looked on Jegs website and they don't list pistons for a 413 now but Summit still does.
http://www.summitracing.com/search/depar...e-size/6-8l-413
Re: 413 piston advice [Re: max] #1330590
11/05/12 07:38 PM
11/05/12 07:38 PM
ohio
B5 GTX Offline OP
B5 GTX  Offline OP
ohio
Thanks for the info. No forged pistons off the shelf it looks like, to bad I would think many 413's are still siting around.
Re: 413 piston advice [Re: B5 GTX] #1330591
11/06/12 10:32 AM
11/06/12 10:32 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
There is a guy on E-bay sells complete engine kits for 413 in forged!
do a search
http://www.ebay.com/itm/Chrysler-V-8-413-CID-Master-Engine-Rebuild-Kit-1959-1965-/330752615997
http://www.cleggengine.com/chrysler-v-8-413-cid-master-engine-rebuild-kit-1959-1965.html
this guy say he has forged kits
http://www.flatlanderracing.com/rebuildkitschrys.html
this guy sells 426 kits a stock bore 426 piston will work that is just a .0625 over bore on a 413
http://www.ebay.com/itm/Dodge-Plymouth-4...e#ht_2734wt_759
