Re: Cost of a Hemi ???
[Re: DakFink]
#1330502
11/04/12 02:34 PM
11/04/12 02:34 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Just the long block to my Hemi has cost me over $22K in parts Block $5000 Heads $5500 Rockers $2500 Crank $3641 Rods $1300 Pistons $1000 Valve covers $450 Gear Drive $550 Camshaft $400 Lifters $700 Pushrods $300 Bearings $150 Damper $360 Oil Pan $300 Intake $550 Head gaskets $200 And there are other misc like hardware, etc.
[Re: DakFink]
#1330503
11/04/12 02:35 PM
11/04/12 02:35 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
426 Hemi are like airplanes, there are no cheap( to buy, don't buy cheap parts, new or used , buy the good to excellnet ones to start with ) parts especially new parts
[Re: Cab_Burge]
#1330504
11/04/12 03:02 PM
11/04/12 03:02 PM
It would probably be better to take a long walk off a short pier before one gets started on building a Hemi, something I should have done as well, so they can come to their senses.
[Re: ]
#1330505
11/04/12 04:22 PM
11/04/12 04:22 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Getting a good block is a pain, even a new one...unlink a used 440 block that's been assembled an ran once at least, a new block is going to have some issues, isn't cheap, and neither is the machine work. So to even put the short block togather, takes some time, money, and attention to detail. I should know, I just wrecked one...in 5 passes. Luckily its not bad, but pulliing it back out was not on my agenda.
[Re: Defbob]
#1330506
11/04/12 06:23 PM
11/04/12 06:23 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Ok, lets compare mine. world block 2500 stageV heads 3800 crank 500 rods 700 pistons 280 cam/lifters 700 timing chain 125 head studs 295 intake 500 valve covers 250 rockers 2600 (stageV roller, dichelles shafts, dvorak stands) Carbs 1200 fuel pump (racepumps 2000) 400 Misc. hardware 350 oil pan (Milidon 31581) 350 External oil line 145 oil line 145 oil pump drive 150 valve spring 200 magnafuel shear plates 200 fuel lines 100 fuel pressure regulator 155 throttle linkage 100 air cleaner 900 balancer 275 flywheel 120 machine shop 2000 Al Debevek K-membeer 900 paint, 280 for 1 quart for original PPG formula Gaskets 400 Bearings 375 spark plug wires 180 distributor 150 (includes recurve) This does not count shipping or travel to get some things done. Its not cheap. I could have bought for cheaper but I know what is in my engine. Many of the parts are similar in cost to what is listed below, I did some shopping around for some things to save a buck. It also does not count any mistakes in parts fitment. Tim Quote:
[Re: astjp2]
#1330507
11/04/12 08:42 PM
11/04/12 08:42 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
I have been careful not to keep any evidence of what I have spent putting my BAE hemi together. So the cost is a secret atleast from my wife.
76 Duster
work in progress
[Re: Edge]
#1330509
11/05/12 12:49 AM
11/05/12 12:49 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I will second that !!!!!!!!
When she asks,,,,,,,,,,,,,,,,,,,,,,,,,,,
[Re: Edge]
#1330510
11/05/12 12:59 AM
11/05/12 12:59 AM
Now that I know the goods on you..... it will cost you to keep me quite.
[Re: DakFink]
#1330515
11/05/12 12:14 PM
11/05/12 12:14 PM
Dragula
DOH!!!
I guess I really stepped into this one!!
My apologies guys BUT what I was really questioning is the Street-able Pump Gas Hemis.
From what I have seen so far these are pretty much race pieces and actually decent prices for what you're getting.
My question is the ones I have looked at as complete engines the prices look like those ya'll have quoted for race Hemis.
Another question arises: More than a few times I have seen people say they have had major issues with Hemis after being built. This is the reason I was looking more at complete engines. Have the builder run it and inspect it before I take it. To make sure there are no underlying issues with it.
A race hemi is not 16K if those are the prices your refering to...A used race hemi is a bunch more!
And as far as underlying issues, we were not aware of some of the rather odd changes to the after market block we recieved, nor was there any warning included. We have built blocks from this manufacutrer before, and never had these particular issues before. We caught most of the changes, but missed one major one that's not really somthing you can vissually see, and now we know. Most builders will already know about all the updates, so stick with one that builds them on a regular basis. It will save you headaches later.
As for me, I think I am done with CI blocks based on the initial cost, and then the cost to fix it and nobody seems accountable even though their name is all over it. Not been real happy with mine and the issues, but its almost back togather as a short block.
[Re: DakFink]
#1330516
11/05/12 01:04 PM
11/05/12 01:04 PM
Posts: 4,213 New York
polyspheric
New York
Like other free market items, the price is determined by the most foolish buyer.
Boffin Emeritus
[Re: bwdst6]
#1330519
11/05/12 02:18 PM
11/05/12 02:18 PM
Posts: 1,162 s e mich
ro23car
s e mich
So you're blaming your recent spun bearing issue on the block? I also can't figure out what "CI" refers to?
cast iron?
[Re: bwdst6]
#1330520
11/05/12 04:30 PM
11/05/12 04:30 PM
Dragula
No, I was refering to the water in the oil, issues with head deck flatness, and lastly, the thrust bearing .010" oversized. CI was for cast iron...It was comming apart for more than just me starving #3 rod for oil. I will take credit for my part.
