Re: twisted splines?
[Re: SpareParts]
#1330409
11/04/12 01:07 PM
11/04/12 01:07 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Is the housing bent? I would check toe-in on rear end.
"Just a Bracket car dressed up like a streetcar"
[Re: SpareParts]
#1330413
11/04/12 07:34 PM
11/04/12 07:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put your brake drum/rotor on backwards and turn the nuts on just a couple of turns then give the drum a couple of good pulls... that always gets them out... sure isnt a twisted spline(the splines might be twisted but NOT in the engaged section)
[Re: dartman366]
#1330415
11/04/12 10:26 PM
11/04/12 10:26 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I may have the same problem with my housing The car hopped real bad at Norwalk a few years ago and ever since then I have to force the axles in and out.Looks like I have a job to do this winter Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: MR_P_BODY]
#1330416
11/05/12 02:36 AM
11/05/12 02:36 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Why didn't I think of that lol, thanks much
Any preferred method of trying to straighten it out or just use the press and luck? Thanks guys! Your helping a young gun out
[Re: dartman366]
#1330418
11/05/12 11:53 PM
11/05/12 11:53 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I'll take bent housing for $100.00
same here, had the same issue when I replaced mine after breaking a ring gear.
All answers must be in the form of a question.
I have to go with the crowd here. And I think a brace is just a good idea once you dip into the 11's or so.
[Re: tubtar]
#1330419
11/06/12 03:05 AM
11/06/12 03:05 AM
SpareParts
Janesville, WI
well, we're past that lol
