twisted splines? #1330406
11/04/12 06:01 AM
11/04/12 06:01 AM
Janesville, WI
SpareParts Offline OP
Janesville, WI
Well I attempted to pull the center section out tonight and swap gears between the cars. Something is wrong! Not even with a slide hammer could I get an axle out. It's an 8.75 with Dr. Diff axles, car has been making some very strong passes lately so who. Knows? Am I right?
Re: twisted splines? [Re: SpareParts] #1330407
11/04/12 11:23 AM
11/04/12 11:23 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Sounds like you have some other problem. Twisted splines should not stop an axle from being removed, as they will be twisted outside of the spool or unit and will be straight inside
Re: twisted splines? [Re: SB412DUSTER] #1330408
11/04/12 12:26 PM
11/04/12 12:26 PM
Penna
70satelliteguy Offline
Penna
"Sounds like you have some other problem. Twisted splines should not stop an axle from being removed, as they will be twisted outside of the spool or unit and will be straight inside "
Re: twisted splines? [Re: SpareParts] #1330409
11/04/12 01:07 PM
11/04/12 01:07 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Is the housing bent? I would check toe-in on rear end.
"Just a Bracket car dressed up like a streetcar"
Re: twisted splines? [Re: 70satelliteguy] #1330410
11/04/12 01:07 PM
11/04/12 01:07 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I'll take bent housing for $100.00
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: twisted splines? [Re: Just-a-dart] #1330411
11/04/12 01:15 PM
11/04/12 01:15 PM
Janesville, WI
Janesville, WI
Doesn't appear to be, I bent the last housing, when I get back to the shop I'll look it over better. Should probably brace it but my car is one of those that looks like it should be about 2sec slower lol less is more.
Re: twisted splines? [Re: SpareParts] #1330412
11/04/12 02:30 PM
11/04/12 02:30 PM
Easy way to tell on the bent housing after you get the axles out is to use two straight edges against the axle bearing flanges and have someone hold a measuring tape on the end about 15 inches from the center of the housing to the front and then to the rear and then up and down, if the difference is more then a 1/8 inch bewteen the front and back and up and down you have a bent bousing I bent the heck out of my 8 3/4 housing with no back brace and ladder bars running low tens at 3450 lbs with 1.43 60 ft. times It has a cut down and narrowed truck Dana 60 in it now My axles had to be pried out of the 8 3/4 housing on the passenger side, they also had to be beat in with a wood 2x4 with a BFH It would lift the right rear tire off the ground first when jacking the rear up under the center section, the car was talking to me but stupid me, I wouldn't listen
Re: twisted splines? [Re: SpareParts] #1330413
11/04/12 07:34 PM
11/04/12 07:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put your brake drum/rotor on backwards and turn the
nuts on just a couple of turns then give the drum a
couple of good pulls... that always gets them out...
sure isnt a twisted spline(the splines might be twisted
but NOT in the engaged section)
Re: twisted splines? [Re: bigtimeauto] #1330414
11/04/12 08:22 PM
11/04/12 08:22 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same here, had the same issue when I replaced mine after breaking a ring gear.
Re: twisted splines? [Re: dartman366] #1330415
11/04/12 10:26 PM
11/04/12 10:26 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I may have the same problem with my housing The car hopped real bad at Norwalk a few years ago and ever since then I have to force the axles in and out.Looks like I have a job to do this winter
Gus
64 Plymouth Savoy
Dana 60
Re: twisted splines? [Re: MR_P_BODY] #1330416
11/05/12 02:36 AM
11/05/12 02:36 AM
Janesville, WI
Janesville, WI
Why didn't I think of that lol, thanks much
Any preferred method of trying to straighten it out or just use the press and luck? Thanks guys! Your helping a young gun out
Re: twisted splines? [Re: SpareParts] #1330417
11/05/12 11:02 AM
11/05/12 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a press and V blocks to get it straight, with
2 straight edges... lay the straight edges on each
flange and measure between the 2, top and bottom and
fore and aft(measure out at least 12" from the flange...
if need be cut the flanges off and reweld
EDIT
Put a back brace on it... the traction tends to bend
the tubes forward
Re: twisted splines? [Re: dartman366] #1330418
11/05/12 11:53 PM
11/05/12 11:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
All answers must be in the form of a question.
I have to go with the crowd here.
And I think a brace is just a good idea once you dip into the 11's or so.
Re: twisted splines? [Re: tubtar] #1330419
11/06/12 03:05 AM
11/06/12 03:05 AM
Janesville, WI
Janesville, WI
well, we're past that lol
