Final polish and wax before assembly... #1330301
11/03/12 11:57 PM
11/03/12 11:57 PM
MO
cdp Offline OP
cdp  Offline OP
MO
My cars had a rotisserie paint job and been sitting for nearly 15 years now without assemble. It has been wet sanded and polished way back after the paint dried.
Now that I'm pulling it out and am starting assembly, what should I apply to the paint before installing all the chrome trim, etc..
Re: Final polish and wax before assembly... [Re: cdp] #1330302
11/06/12 11:51 AM
11/06/12 11:51 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Do you have a machine to polish with or are you planning on doing it by hand ?
I recommend a Porter Cable D?A polisher to anyone that plans on doing any at home detailing. For polish you can use a white foam pad and some Meguiars 205 polish. If you need to go more aggressive a yellow pad and the 105 compound will take most anything out without swirling the finish like a wool pad and a heavy cut compound will.
For wax Mequiars NXT is easy to find but you can uses any major brand wax with pretty good results, Remember the wax is for protecting the finish, Not making it shiny. Thats the polish's job.
Everyone else is going to tell you to use Zanio's. I have no experience with it but I use the Meguiars every day and my customer never have a complaint.
Re: Final polish and wax before assembly... [Re: cdp] #1330303
11/06/12 01:23 PM
11/06/12 01:23 PM
Rhode Island
jml19621 Offline
jml19621  Offline
Rhode Island
I would recommend any stripes decals and the like be put on before you wax the car. I did a car once tried to put the 'bill board' on the side. Needless to say it was a challenge trying to get it to adhere to the surface.
Re: Final polish and wax before assembly... [Re: jml19621] #1330304
11/06/12 01:36 PM
11/06/12 01:36 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I agree. Polish it do the decals, mask off the decals then wax it.
Re: Final polish and wax before assembly... [Re: AdamR] #1330305
11/06/12 01:53 PM
11/06/12 01:53 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Wouldn't polish leave some oils on there as well?
Re: Final polish and wax before assembly... [Re: MI_Custumz] #1330306
11/06/12 03:32 PM
11/06/12 03:32 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
No.A polish should make the surface shiny by fixing the imperfections in the paint, not cover them up with fillers and silicone. It doesnt stay on the paint.
You will still need to wipe down the area with alcohol or a wax cleaner but it wont dull the finish.
Re: Final polish and wax before assembly... [Re: AdamR] #1330307
11/06/12 09:57 PM
11/06/12 09:57 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I have Zainos on hand. Bought their kit a month ago and have a Portercable polisher on the way. The car has been wetsanded and polished on at the paint shop.
I just want to do any final work prior to assembly. Hate to admit it, but its on my only current Non-mopar....that I'm needing to do some final polish on at this point.
But, after winter, the RR is back in for final assembly, polish and decals.
