833 OD ?????? #1330246
11/03/12 10:27 PM
11/03/12 10:27 PM
Outside
thedriver Offline OP
Outside
Did 833 od's ever come with a cast iron tailhousing bolted to the aluminum main case from the factory??
1973 challenger
Dana. 4 speed. Low deck.
Re: 833 OD ?????? [Re: thedriver] #1330247
11/03/12 10:30 PM
11/03/12 10:30 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The long tailshft versions in the trucks did. Don't know about the A and F body shorties.
Re: 833 OD ?????? [Re: B5 Bee] #1330248
11/03/12 11:03 PM
11/03/12 11:03 PM
Outside
Outside
So would the iron tailhouse eliminate that problem where that bushing or whatever it was from getting wore out and causing the tailshaft to wobble in the housing?
1973 challenger
Re: 833 OD ?????? [Re: thedriver] #1330249
11/03/12 11:09 PM
11/03/12 11:09 PM
I believe that is an aluminum case countershaft issue
Re: 833 OD ?????? [Re: RapidRobert] #1330250
11/04/12 12:51 AM
11/04/12 12:51 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
he tailshaft housing has nothing in common with the counter shaft
I am truckless..
Re: 833 OD ?????? [Re: 340SHORTY] #1330251
11/04/12 01:01 AM
11/04/12 01:01 AM
Outside
Outside
Ok thanks. Would you guys put one of these behind a 408?
What's a machinist charge to fix the floating countershaft issue/bearing retainer to work with my sb?
1973 challenger
Re: 833 OD ?????? [Re: thedriver] #1330252
11/04/12 01:54 AM
11/04/12 01:54 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think they have a 3.09 1st "granny" low gear. And it's a 3 speed trans that has an overdrive. The gear spreads are large. A 4" stroker doesn't need a low 1st gear.
Re: 833 OD ?????? [Re: autoxcuda] #1330253
11/04/12 02:05 AM
11/04/12 02:05 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Ya but you can sure annihilate the tires!
Re: 833 OD ?????? [Re: DaytonaTurbo] #1330254
11/04/12 02:25 AM
11/04/12 02:25 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had one in the FD, It was an iron one.
I didn't like it. The ratio spread was exactly as others had said....It had a huge rpm drop-off from 1-2. For a NON performance app, it was probably fine.
Re: 833 OD ?????? [Re: DaytonaTurbo] #1330255
11/04/12 03:28 AM
11/04/12 03:28 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Right now with my 416, I have to feather the thottle with a stockish converter and 727 with 3.23 rear gears.
Re: 833 OD ?????? [Re: autoxcuda] #1330256
11/04/12 04:16 AM
11/04/12 04:16 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Not to pick nits, but since it has 4 forward gears it is a 4 speed transmission. 3rd is 1 to 1 and 4th is either .73 or .71 to 1.
Re: 833 OD ?????? [Re: nomore65BelvJim] #1330257
11/04/12 01:47 PM
11/04/12 01:47 PM
Manitoba, Canada
Manitoba, Canada
And to nitpick even further, in the OD 833, they swapped 3rd and 4th gears around inside the transmission so you could say 3rd gear is .71 or .73 and 4th gear is 1:1 Although if you flip the 3-4 shift lever updside down on the trans, you can retain the normal shift pattern instead of the wonky one the OD 833 vehicles had stock.
Re: 833 OD ?????? [Re: DaytonaTurbo] #1330258
11/04/12 01:53 PM
11/04/12 01:53 PM
I had one behind a stock 360 in a 64 dart & as Frankenduster said the spread between 2 of the gears was terrible even in a DD
Re: 833 OD ?????? [Re: DaytonaTurbo] #1330259
11/04/12 01:56 PM
11/04/12 01:56 PM
Outside
Outside
Is the passon setup the same way with 3rd and 4th flipped around like that inside?
I didn't realize the od's had a different pattern on the shifter?!
1973 challenger
Re: 833 OD ?????? [Re: thedriver] #1330260
11/04/12 04:45 PM
11/04/12 04:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
To the non supporters of the OD833. I say bullcrap. Ive had 1 in my 81 shorty PU for years. Its behind a 340 with a 268/272 .450/.455 cam with a 6 pac on top. Out back is a set of 3.91s with 275/60/15s. I love the OD833. I can cruse around town and theres not much that can beat me from stop light to stop light. Out on the highway the mileage is great. I
As I dont tow anything with my crewcab longbox dually Im considering changing the NP435 out and install my spare OD833 in its place.. get better mileage out of my 340 than I did when I bought the truck with the factory /6 in it....
I am truckless..
Re: 833 OD ?????? [Re: thedriver] #1330261
11/04/12 06:30 PM
11/04/12 06:30 PM
Manitoba, Canada
Manitoba, Canada
No, the passon is a totally new gear set.
Re: 833 OD ?????? [Re: thedriver] #1330262
11/04/12 07:50 PM
11/04/12 07:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
The 833 O.D doesn't have a different shift pattern in it, the shift arms are reverse on the 3-4 gear selector so the shift patter stays the same,1-2,2-3,3(direct)-4(O.D.) not backwards or upside down I have several NP 833 O.D., one out of a F or A body and one out of a van, same or similar to the B-E bodys I'm told. I'm planning on using the short tailshaft trans in my 1969 Dart GTS 383 4 speed car
Re: 833 OD ?????? [Re: Cab_Burge] #1330263
11/05/12 09:32 AM
11/05/12 09:32 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yup....the lever was flipped at the factory, so you had 1-2-DIRECT-OD
gear ratios are 3.09 1st, 1.67 2nd, 1.00 3rd .73 4th
it's a nice spread (about the same as a GM TH700R4) if you build an engine with a nice flat torque curve, it would work great with the A833OD. with that gear spread and the low first gear, a 3.23 or 3.55 is an ideal rear end ratio, which nets you a 10:1 to 11:1 overall first gear ratio, and a 2.36-2.59 4th gear ratio (which yields a 2000-2250 RPM cruise at 70mph with 27" tall tires like 255/60R15's)
but you have to plan for the gear spread. for me, that means slightly shorter duration, wider LSA cam, which sacrafices a bit of peak torque for a flatter torque curve where hopefully 90% of peak torque is available from say 2000-5000 RPM....
I have one from the factory in my slant 6 duster with 3.23's and 25" tall tires. great tranny, gear spread doesn't bother me. would be an awesome tranny behind a mild magnum headed 318 or 360, or even a stockish 5.7L hemi.
mine is an early tranny, full cast iron case.
2017 Grand Cherokee Overland
