engine coolant #133022
10/06/08 03:57 PM
10/06/08 03:57 PM
minnesota
P
president61 Offline OP
P
minnesota
what keeps your engine cooler, plain water or 50/50 mix with antifreeze? (67 coronet 440)
Re: engine coolant [Re: president61] #133023
10/06/08 03:58 PM
10/06/08 03:58 PM
Kirkland, Washington
Pacnorthcuda Offline
plain water (it has better heat transfer)
Re: engine coolant [Re: president61] #133024
10/06/08 08:12 PM
10/06/08 08:12 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
But for corrosion protection,you should use anti freeze.I mix mine in a 70/30 mix using distilled water.
Nautilus Racing-
