E Body window inside the door felt. Where to buy? #1330082
11/03/12 10:36 AM
11/03/12 10:36 AM
Stafford, Virginia
ChallengerVert Offline OP
Stafford, Virginia
Anyone know where I can get inside the door felt for a 1970 E body? These are the pieces that guide the window. Pictures attached. I have looked for these everywhere on line and can’t find anything.
Re: E Body window inside the door felt. Where to buy? [Re: ChallengerVert] #1330083
11/03/12 10:37 AM
11/03/12 10:37 AM
Stafford, Virginia
Stafford, Virginia
Picture inside the door
Re: E Body window inside the door felt. Where to buy? [Re: ChallengerVert] #1330084
11/04/12 07:19 PM
11/04/12 07:19 PM
Stafford, Virginia
Stafford, Virginia
Anyone know where to get these?
Re: E Body window inside the door felt. Where to buy? [Re: ChallengerVert] #1330085
11/04/12 08:01 PM
11/04/12 08:01 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I don't have a direct answer for you. A couple of years ago this topic came up here. Someone found some material similar to whats on the Mopar ones. Seems like it was a GM site for Camaros/ Firebirds. They had to use their original ones and glue on the new material.Wish I could find the question when it came up before. Unless things have changed, ther are no reproduced part for these.
Terry
Re: E Body window inside the door felt. Where to buy? [Re: 71vert340] #1330086
11/04/12 08:12 PM
11/04/12 08:12 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
As much as I hate to put this on the Mopar site, go to www.camarocentral.com and do a search for door panel guides fuzzy material, part number DWN-405. This looks likes it's similar to what was used on the Mopar guides. $12.95 for 6 pieces of material.
Terry
Re: E Body window inside the door felt. Where to buy? [Re: 71vert340] #1330087
11/04/12 10:44 PM
11/04/12 10:44 PM
Stafford, Virginia
Stafford, Virginia
Many Thanks!! I am going to try these!
Re: E Body window inside the door felt. Where to buy? [Re: ChallengerVert] #1330088
11/04/12 10:58 PM
11/04/12 10:58 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Found the previous post on this subject from June 7, 2011. Do a search using "e body fuzzy felt door guides" and you should see it if you search for newer than 3 years in the Moparts Restoration and A 12 Forum. Good luck and let us know how it turns out.
Terry
