Fuel fill on six pack center carb
#1329844
11/02/12 12:41 PM
11/02/12 12:41 PM
Posts: 907 Mississauga, Canada
KARLN
Mississauga, Canada
Where is the correct spot to fill fuel on the center carb to prime if the car has been sitting idle for weeks? I know some old school guys just pour it down the carb but I remember seeing a specific spot on the carb to fill the bowl.
thanks!
B5 Challenger T/A
Re: Fuel fill on six pack center carb
[Re: RobX4406]
#1329847
11/02/12 01:30 PM
11/02/12 01:30 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Hit the pharmacy for a kids liquid medicine syringe. Usually they give them away if you ask.
Fill syringe and squirt it down the vent tube.
what he said...
[Re: screamindriver]
#1329850
11/03/12 07:12 PM
11/03/12 07:12 PM
KARLN
Mississauga, Canada
thank you! Get my T/A home from the painter tomorrow so will want to fire her up before putting away for the winter.
B5 Challenger T/A
[Re: KARLN]
#1329851
11/03/12 10:59 PM
11/03/12 10:59 PM
Posts: 1,012 indiana
mcmopars
indiana
thanks!
what am i missing? i dont drive some of my cars for months and i dont need to prime,is it a 6 pack thing???
[Re: mcmopars]
#1329852
11/03/12 11:16 PM
11/03/12 11:16 PM
KARLN
Mississauga, Canada
Pretty sure it's a Holley 2300 thing. I've heard other buddies with Holley tri-packs on Vettes having the same probelm.
B5 Challenger T/A
[Re: 1cuda]
#1329855
09/06/14 02:47 PM
09/06/14 02:47 PM
Posts: 3 SE Michigan
T/A-SRT8
SE Michigan
So I picked up my 1970 T/A today from having carbs rebuilt(6pack), car ran fine on the drive home 20 miles, car sat for about an hour and my son wanted to go for a drive we cruise around for 15 minutes a and a couple WOT runs, pull down my street and stalls right in front of my house. Cranked over would not start, opened hood noticed clear fuel filter had no gas in it. pour small amout of gas down center carb, car started up for 10 seconds repeated this for 20 minutes car would only for run as long as the gas i poured in carb would last, fuel filter now has gas in it but the battery is dead. I just recently switched from electric fuel pump to mechinical. what could the problem be?
[Re: T/A-SRT8]
#1329858
09/06/14 04:48 PM
09/06/14 04:48 PM
Posts: 15,429 Omaha Ne
TJP
Omaha Ne
Also check for loose connections or bad hose any where along the inlet line from the sending unit to the pump. Hook up a vacuum gauge to the inlet side crank the motor and check for vacuum Repeat on output side checking for pressure.
