What is the best way to mount (and allign) a door?
#1329626
11/01/12 07:27 PM
11/01/12 07:27 PM
Posts: 183 Charleston, SC
bronco9588
Charleston, SC
Putting the door back on after rebuilding some hinges. What is the best way to put it back on and get it all aligned? It seems like there is a lot of play with the hinge mounts/ backing plates. Is it best done before or after putting the fender on?
'73 Charger Petty Blue, Black Vinyl, and Gill Slits
727 torque-flight
400 BB Chrysler
8 3/4 rear
Re: What is the best way to mount (and allign) a door?
[Re: bronco9588]
#1329628
11/01/12 08:53 PM
11/01/12 08:53 PM
Posts: 12,075 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Typically you hang the doors first and align them to the quarters. Then you hang the fenders and align them to the doors. Sometimes you get lucky and the doors work with the fenders as they are already mounted. Then all you have to contend with is getting to the hinge to body bolts.
But sometimes the fenders need a little massaging after the doors have been off.
Good luck!
Master, again and still
[Re: 4406bbl]
#1329630
11/02/12 04:43 AM
11/02/12 04:43 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is a recommendation I read somewhere:
Body Panel Alignment 1. Replace pins and overhaul door hinges. 2. Align doors to body. 3. Align door latches to doors. 4. Align hood to body. 5. Align fenders to doors and hood.
