HEMI I BEAM ROD #1329517
11/01/12 01:27 PM
11/01/12 01:27 PM
tn
robnbird Offline OP
robnbird  Offline OP
tn
WHO ALL MAKES A 6.865 I BEAM HEMI ROD? AND WHICH ONE WOULD YOUR PREFERENCE ? THANKS ROB
Re: HEMI I BEAM ROD [Re: robnbird] #1329518
11/01/12 05:19 PM
11/01/12 05:19 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Manley
2011 Drag Pak Challenger
Re: HEMI I BEAM ROD [Re: rickseeman] #1329519
11/01/12 06:28 PM
11/01/12 06:28 PM
dogdays Offline
dogdays  Offline
I'd favor Crower or Oliver, although you'd have to talk to either of them to get what you wanted. I have some Crower I-beams 7.100" long and they are impressive.
R.
Re: HEMI I BEAM ROD [Re: robnbird] #1329520
11/01/12 11:56 PM
11/01/12 11:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
WHAT IS THE HORSEPOWER OF THE INTENDED APPLICATION ?
Re: HEMI I BEAM ROD [Re: JohnRR] #1329521
11/02/12 12:27 AM
11/02/12 12:27 AM
tn
robnbird Offline OP
robnbird  Offline OP
tn
not sure , 800+
Re: HEMI I BEAM ROD [Re: robnbird] #1329522
11/02/12 02:17 AM
11/02/12 02:17 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Check with K1, they used to have one before Wiesco bought them. Tim
Re: HEMI I BEAM ROD [Re: astjp2] #1329523
11/02/12 08:48 AM
11/02/12 08:48 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I bought a set of these Manley I-beam rods from Mike Bogina. He had them on the shelf. I had them checked by my machinist and the rod bolts had some galling on them from the factory, so we had to replace the rod bolts, dowels and resize the big ends to fix the problems from Manley. I'd only buy rods new from the factories after that so I can return them if they aren't right. I don't know if Manley still makes these or not.
Floyd Lippencott IV
Re: HEMI I BEAM ROD [Re: mr_340] #1329524
11/02/12 08:52 AM
11/02/12 08:52 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Childs & Albert used to make a nice set of I-beam rods. I bought a used set from Joe Teuton. They have CARR bolts in them, so replacing those is around $800/set. I don't know if the dowels can be replaced or not. They are around 900 grams, as are the Manley I-beams.
Floyd Lippencott IV
Re: HEMI I BEAM ROD [Re: mr_340] #1329525
11/03/12 12:33 PM
11/03/12 12:33 PM
Salinas, California
1970Cuda Offline
super street
1970Cuda  Offline
super street
Salinas, California
Rob I have a set of Crower 6.86 I-beam rods if you're interested. PM me. Jim
