340 power steering pump? #1329458
11/01/12 12:42 PM
11/01/12 12:42 PM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
I have been checking out NAPA and RockAuto for a rebuilt power steering pump. RockAuto lists specifically about the 340 application. Was there a difference between 340 pumps versus other engine applications? This application is for a 1970 340 Duster.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 340 power steering pump? [Re: FJR doc] #1329459
11/01/12 05:36 PM
11/01/12 05:36 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
FWIW, the 70-71 Chrysler parts book shows the same pump for 318 & 340 A bodies. It also lists A bodies as having the "threaded hole pump shaft" style, while other bodies could have that or the "key slotted pump shaft" style.
I can post the parts book page if you think that would be of any help.
Re: 340 power steering pump? [Re: moparfan53] #1329460
11/01/12 08:19 PM
11/01/12 08:19 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Your car should have the pressed on 3 spoke pulley with a Federal pump
