Mechanical Speedo Repair Q: Magnets #1329258
10/31/12 06:52 PM
10/31/12 06:52 PM
US of A
A38s! Offline OP
A38s!  Offline OP
US of A
Want to use a 85 mph M-body speedo to repair a M-body cop unit.
Cop speedo would jump. Thinking it was bushings, thought I'd swap some in. Problem turned out to be a crack in the nylon shaft, causing the magnet arms to wobble enough and contact the field plate cup.
Are the 85-125 magnets the same? Size-wise, they're identical, but could they be diff "strengths".
Pic 1
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: Mechanical Speedo Repair Q: Magnets [Re: A38s!] #1329259
10/31/12 06:53 PM
10/31/12 06:53 PM
US of A
A38s! Offline OP
A38s!  Offline OP
US of A
No PNs anywhere.
Pic 2
Re: Mechanical Speedo Repair Q: Magnets [Re: A38s!] #1329260
10/31/12 10:52 PM
10/31/12 10:52 PM
It looks identical & I'd be surprised if it wasn't the exact same strength
Re: Mechanical Speedo Repair Q: Magnets [Re: RapidRobert] #1329261
10/31/12 10:54 PM
10/31/12 10:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Same measurements should mean same strength.
